Hello everyone.
I have an application where i need to log the data in MS Access and later from other table i need to read other data.
But i am not getting any node related to MS Access. I have the Description, the UID, Database name and table but i dont know how i can send Data (csv) to this Table.
I tried to use ODBC tool but i couldn´t find an good explanation how i should code it so that i can write and read from a table from MS Access.
Thanks for any help.
Are you wanting to do this on Windows or Linux?
Windows if this is possible
Yes, that is fairly straight-forwards.
This page tells you how to set up the ODBC driver: Administer ODBC data sources (microsoft.com)
Then you should be able to use one of the ODBC nodes.
Thanks. Is there also a way to realise this in node-red, for example with the ODBC Query?
ODBC is a driver standard. You have to configure it separately. Once configured on the device, the read/write can be done in node-red.
I connected to the ODBC and can open my table in MS Access
How can i write now some input over node-red to the ODBC table?
What examples does the odbc node give you?
i have this example from a youtube video but it doesnt work for me
espacially because i cant create the right connection
Bear in mind that I don't use this node and haven't done anything with ODBC in years ... but surely it is a case of changing line 4 cStoreData to be the name of your ODBC connection? The rest of the example is just a standard SQL statement.
