How to reduce 5000 lines of code to just a few using a variable?
Dear reader,
I'm a intern at a company that distrubits camera. Together with my internship supervisor we are making software for Hikvision camera's using Node-Red.
We got our program working, however we have a function that consists of more than 5000 lines of code. We're sure this can be reduced to a few lines of code. I know we should make some values variable but we cannot find out how to make this working.
So I hope someone on this forum is able to help us? :sweat_smile:
Here are the flows and code:
flows (5).json (981.2 KB)
I think it should look something like this:
msg.headers = {};
msg.headers['content-type'] = 'application/xml';
if (msg.payload.length == 99)
    msg.payload = '<?xml version="1.0"?><LPListAuditSearchResult xmlns="http://www.std-cgi.org/ver20/XMLSchema" version="2.0"><LicensePlateInfoList><LicensePlateInfo><id>1<id><LicensePlate>'+msg.payload[0].Kenteken+'</LicensePlate><type>'+msg.payload[0].Type+'</type><effectiveTime>'+msg.payload[0].Geldig+'</effectiveTime></LicensePlateInfo>
Sincerly,
Gino
First off, what is the function suppose to do? i.e. explain what output you need based on the msg.payload.length.
As suggested, you need a specification. Write a detailed specification of what goes into the function and what should come out. Once you have a spec then a solution can be found.
Hi, forgive me for saying so but - WOW.
↑ that is not how you deal with variable sized data.
First and easy fix is to loop through the array to build your XML - but this is a botch job & not recommended.
The better solution is to work with native JS objects & build / transform the SQLite data into the correct shape Js object then pass it through an XML node to convert the JS object into XML.
If you can provide 2 things...
  1. a sample of 2 SQLlite rows of data by adding a debug node after the SQLite node, query the DB for 2 rows (limit 2) then use the copy value button that appears under your mouse cursor when you hover over the debug output.
  2. the final XML that you expect (with the same 2 data rows converted to XML)
I can show you how to do this in a more "node-red" way.
I'll reiterate @Steve-Mcl's "Wow!". That's very much not the way to do this kind of task.
I'm not trying to put down your efforts at getting something working, but if you're doing this as a commercial product you really should find an experienced software developer, either a contractor for a few months, or a permanent employee if you're going to be doing more, similar things in the future.
It may seem like unnecessary cost, even for a couple of months of a contractor, but it will pay off long term with much more maintainable and upgradeable code, fewer bugs, and fewer customer problems.
I'm sorry but the code is from the previous intern.
We are trying to get this data:
I meant no offence - only to highlight it was not a great way to handle this type of task (completely unmaintainable and lots of error prone copy+pasting). I am sorry if offence was taken.
To help you, as I said before, 2 things are needed...
I will spell them out a little clearer..
  1. Add a debug AFTER sqlite node
    • capture the output of the payload by clicking the "copy value" button that appears under your mouse in the debug window
    • I only need a few rows
  2. Provide a "finished" XML string for these data rows (as a code block, not a screenshot)
The reason why anyone would need this ↑ - I dont have access to your data to try something, I would need a final (good) XML to compare what my demo flow produces is correct for you.
If you dont want to do that, then I suggest using the following approach...
sqlite --> function (transform the rows into a JS object that represents the final XML) --> XML node --> file node.
My personal view, yes, agree, a serious company should bear the costs for their work to be done. I think we see this more often, companies seeking "free" advice and help. Maybe room for a new category, "Seek & Sell" ?
[{"id":1,"Kenteken":"34jlrd","Type":"blackList","Geldig":"2020-12-12","AantalKeren":"44"},{"id":2,"Kenteken":"68-bg-po","Type":"whiteList","Geldig":"2020-12-12","AantalKeren":"48"},{"id":3,"Kenteken":"01aa01","Type":"blackList","Geldig":"2020-12-12","AantalKeren":"48"},{"id":4,"Kenteken":"02aa01","Type":"whiteList","Geldig":"2020-12-12","AantalKeren":"48"},{"id":6,"Kenteken":"04aa01","Type":"whiteList","Geldig":"2020-12-12","AantalKeren":"48"}]
{"_msgid":"615ef601.067c28","payload":"<?xml version=\"1.0\"?><LPListAuditSearchResult xmlns=\"http://www.std-cgi.org/ver20/XMLSchema\" version=\"2.0\"><LicensePlateInfoList><LicensePlateInfo><id>1<id><LicensePlate>34jlrd</LicensePlate><type>blackList</type><effectiveTime>2020-12-12</effectiveTime></LicensePlateInfo><LicensePlateInfo><id>2<id><LicensePlate>68-bg-po</LicensePlate><type>whiteList</type><effectiveTime>2020-12-12</effectiveTime></LicensePlateInfo><LicensePlateInfo><id>3</id><LicensePlate>01aa01</LicensePlate><type>blackList</type><effectiveTime>2020-12-12</effectiveTime></LicensePlateInfo><LicensePlateInfo><id>4</id><LicensePlate>02aa01</LicensePlate><type>whiteList</type><effectiveTime>2020-12-12</effectiveTime></LicensePlateInfo><LicensePlateInfo><id>5<id><LicensePlate>04aa01</LicensePlate><type>whiteList</type><effectiveTime>2020-12-12</effectiveTime></LicensePlateInfo><LicensePlateInfo><id>6<id><LicensePlate>05aa01</LicensePlate><type>blackList</type><effectiveTime>2020-12-12</effectiveTime></LicensePlateInfo><Li...","headers":{"content-type":"application/xml"}}
Your XML in the 2nd message is incomplete...
Try reducing the query to 2 rows and try again.
KENTEKENS.txt (107 Bytes)
Here you go...
Your 5000 line hard coded function becomes 100% dynamic (1 row or 10000 rows - its the same)...
//make the base JS object
var dataStructure ={
    "LPListAuditSearchResult":{
            "xmlns":"http://www.std-cgi.org/ver20/XMLSchema","version":"2.0"
        "LicensePlateInfoList": [
                "LicensePlateInfo":[ ]
//make a data item from a DB row
function makeDataRow(row) {
    return  {
        "id":[row.id],
        "LicensePlate":[row.Kenteken],
        "type":[row.Type],
        "effectiveTime":[row.Geldig]
for (let i = 0; i < msg.payload.length; i++) {
    const row = msg.payload[i];
    //add the converted DB row to the JS dataStructure object
    dataStructure.LPListAuditSearchResult.LicensePlateInfoList[0].LicensePlateInfo.push(makeDataRow(row));
msg.payload = dataStructure
Demo flow...
[{"id":"2ebcaf60.912b7","type":"inject","z":"4656711a.6b16a","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":330,"y":280,"wires":[["d818ecec.c4de"]]},{"id":"d818ecec.c4de","type":"function","z":"4656711a.6b16a","name":"Database data (fake query result)","func":"msg.payload = [{\"id\":1,\"Kenteken\":\"34jlrd\",\"Type\":\"blackList\",\"Geldig\":\"2020-12-12\",\"AantalKeren\":\"44\"},{\"id\":2,\"Kenteken\":\"68-bg-po\",\"Type\":\"whiteList\",\"Geldig\":\"2020-12-12\",\"AantalKeren\":\"48\"},{\"id\":3,\"Kenteken\":\"01aa01\",\"Type\":\"blackList\",\"Geldig\":\"2020-12-12\",\"AantalKeren\":\"48\"},{\"id\":4,\"Kenteken\":\"02aa01\",\"Type\":\"whiteList\",\"Geldig\":\"2020-12-12\",\"AantalKeren\":\"48\"},{\"id\":6,\"Kenteken\":\"04aa01\",\"Type\":\"whiteList\",\"Geldig\":\"2020-12-12\",\"AantalKeren\":\"48\"}]\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":580,"y":280,"wires":[["5f772990.9cb2b8","b2fc9b8f.7fef28"]]},{"id":"5f772990.9cb2b8","type":"debug","z":"4656711a.6b16a","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":930,"y":280,"wires":[]},{"id":"b2fc9b8f.7fef28","type":"function","z":"4656711a.6b16a","name":"transform to nice JS object","func":"//make the base JS object\nvar dataStructure ={\n    \"LPListAuditSearchResult\":{\n        \"$\": {\n            \"xmlns\":\"http://www.std-cgi.org/ver20/XMLSchema\",\"version\":\"2.0\"\n        },\n        \"LicensePlateInfoList\": [\n            {\n                \"LicensePlateInfo\":[ ]\n            }\n        ]\n    }\n}\n\n//make a data item from a DB row\nfunction makeDataRow(row) {\n    return  {\n        \"id\":[row.id],\n        \"LicensePlate\":[row.Kenteken],\n        \"type\":[row.Type],\n        \"effectiveTime\":[row.Geldig]\n    }\n}\n\nfor (let i = 0; i < msg.payload.length; i++) {\n    const row = msg.payload[i];\n    //add the converted DB row to the JS dataStructure object\n    dataStructure.LPListAuditSearchResult.LicensePlateInfoList[0].LicensePlateInfo.push(makeDataRow(row));\n}\nmsg.payload = dataStructure\nreturn msg;\n\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":560,"y":340,"wires":[["ecb6b334.0d41","61af7ae1.0ee784"]]},{"id":"ecb6b334.0d41","type":"xml","z":"4656711a.6b16a","name":"","property":"payload","attr":"","chr":"","x":770,"y":340,"wires":[["497a134c.f828fc"]]},{"id":"497a134c.f828fc","type":"debug","z":"4656711a.6b16a","name":"Finished XML","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":940,"y":340,"wires":[]},{"id":"61af7ae1.0ee784","type":"debug","z":"4656711a.6b16a","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":790,"y":400,"wires":[]}]
PS - your original XML is still invalid (and the exact reason I said you should work with Js objects instead of a hand coded string concatenation)
