How to refresh editableList
I have a node using an editableList.
Each item content, for this editableList, depends on an other config parameter of the node. And when this parameter changes, I would like to refresh the editableList.
I have not seen anything to do such a thing, can you help ?
Thx
HI @Lionel
what do you mean by refresh? Empty the list and add new elements? Keep the existing items but change something about them?
Hi @knolleary
I want to partially keep the existing data, add or remove some items.
The docs for editableList are here: EditableList Widget : Node-RED including the addItem and removeItem functions.
Do you suggest, I remove all the items of the EditableList and then I re-populate ?
I have tried this way, but I have had an issue with .editableList('empty'), it seems the EditableList is not cleared
Sorry, it is my bad, I forget the # before the element name !!!
Thx, it works fine now using you suggestion.
