Can anyone point me to a really simple example of the use of editableList? I am trying to use it to create an array of simple objects, each consisting of a couple of numbers and a string. I am looking at the code for the switch node but I am struggling to see the wood for the trees as most of the code is to do with the complexities of the data rather than the list itself, and I have little experience in the html area.
That has confused me further, as it seems to be handling it in a different way to that in, for example, the switch node. It is specifically oneditprepare() where I am having problems with understanding what I need to do.
Looking through the core code, I think the ActionList dropdown includes one of the more straight-forward uses of editableList:
- You create an
<ol>element, convert it to aneditableList. - in the config for the list, you provide an
addItemfunction that is called whenever there is an item to add to the list. It is provided acontainerwhich is the parent DOM element for the item, along with the data item itself. It's then over to you to create the list item's DOM representation insidecontainer.
There are a number of configuration options and functionality around sorting and filtering. All documented here EditableList Widget : Node-RED, albeit without an end-to-end example to help get started..
Thanks, I will have a look.
