How to remove node-red-contrib-mssql
I suspect you have not ran npm in the correct directory.
Your node-red directory is typically c:\users\user\.node-red\
That is where you should run the npm command
If in doubt, look at the log output that node-red shows when you start it - you will see the user directory in the log output.
