Differences between node-red-contrib-mssql-plus in linux/windows?
My main node-red (3.0) installation at work is on a CentOs VM. I am using node-red-contrib-mssql-plus v0.7.3 to access some MSSQL DBs and I have no problems.
I need to make some installs on a few PCs that will serve just as connected HMIs. I just made a fresh install on a test machine to make sure it works before deployment to the final machine. I used a windows VM, and just did a fresh node.js and node-red install, with the same versions I'm running on the other machine.
I am accessing both VMs from my laptop, within the local network. However, when I want to configure the base nodes for the DBs, there are substantial differences on what they show:
This is on the CentOS machine vs the Windows machine, side by side:
As you can see, the available options displayed are substantially different, with Windows showing less than half of the options.
Any idea of what might be the cause? as I said, the node-red and the node versions are the same on both machines.
You probably have the old node-red-contrib-mssql node installed. The plus version is a fork because that old version is abandoned.
Uninstall any other MSSQL node, restart & refresh browser.
FYI - I am using the plus node on Linux and Windows. Don't see such issues.
Actually, it was the mssql-plus one. Same version.
I think I figured it out, it might have had something to do with the installation. Whenever I installed from the palette manager, this would happen and options would be missing.
I deleted everything, stopped node-red, and then installed the package using npm, from a powershell window running as admin.
Installation was successful, and when I restarted node-red everything was as expected.
Only if you already have to old (non plus) version
Deleted what? Flows? Node_modules? .node-red folder? Node-red?
Installing nodes without -g does not and should not be ran as admin.
And, installing from npm is exactly what the palette manager does.
I had the plus version. Exactly the same as in my other environment.
It was a clean install, so I only had an inject node, the mssql and a debug node. I deleted the mssql-plus package also from the palette manager after deleting the node and configuration node.
I opened an admin powershell and run the npm command as specified on the node description, and it worked. I don't know why, I'm just saying what I did.
Steve is suggesting that you possibly had both the original and the plus version installed.
Not at the same time, I made a mistake installing first, but then uninstalled it before installing the plus version.
In any case, it works now.
The way npm delivers a package is everything at once (in a tgz) - there is no possibility of it grabbing the wrong config node. However, what I have witnessed is when another fork (named alphabetically before node-red-contrib-mssql-plus) is that the plus version picks up the config node of the non plus version. Which is why I suggested you might have the old version installed.
Then it is likely you didn't restart node-red or the browser wasn't fully refreshed
