hello, everyone
I installed the nodered on ubuntu 18.04 with snap, now I want to enable the HTTPS Access and the Username/password based authentication, it takes me much time to find the setting.js file, at last, I found it here ''
I don't know if it means the setting.js file is located '/root/snap/node-red/675/setting.js'? what does the 675 mean here?
then, I have to run this command to generate the password following the instruction, but the command line says it cannot find the command node-red,
how should I run the command to generate password?
could anyone give me some advice? thanks in advance
