How to sample a payload
Hello !
I created a graph with a signal updated every second but over a day I saturate my dashboard .. how to write a function that would output a point every 5 minutes for example?
Thanks for help
maybe the smooth node. It has options for max, min, mean and to reduce the output over n samples.
Thanks for answer, this is a good node ... I'm trying it on my flow ... I'll tell you the result
Hello, the smooth node works fine !!! thanks for help :grinning:
