Hi all,
I have mounted a window open/closed sensor at my window (which sends the data via mqtt) and I am planning to do the following with NodeRed (and HomeAssistant):
If I open the window, NodeRed should save the climate settings and turn the climate off. When the window gets closed again it should turn on the climate with the same setting than before.
The following settings are possible with the climate:
At the moment I save the climate state in a flow variable like this:
"id": "97421084ccfd057c",
"type": "tab",
"label": "Flow 1",
"disabled": false,
"info": "",
"env": []
"id": "5e5c8a874d64033a",
"type": "api-call-service",
"z": "97421084ccfd057c",
"server": "42c5021e.042e7c",
"version": 5,
"debugenabled": false,
"domain": "climate",
"service": "turn_off",
"areaId": [],
"deviceId": [],
"entityId": [
"climate.schlafzimmer_2"
"data": "",
"dataType": "jsonata",
"mergeContext": "",
"mustacheAltTags": false,
"outputProperties": [],
"queue": "none",
"x": 1640,
"y": 435,
"id": "0e1960f6671ea943",
"version": 5,
"service": "set_hvac_mode",
"areaId": [],
"deviceId": [],
"entityId": [
"data": "",
"mergeContext": "",
"queue": "none",
"x": 1670,
"y": 360,
"id": "470a7259b1705568",
"type": "change",
"rules": [
"t": "set",
"p": "climate_state_before",
"pt": "flow",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1135,
"y": 435,
"5e5c8a874d64033a"
"id": "bdcb58795f5e7b70",
"type": "api-current-state",
"version": 3,
"outputs": 1,
"halt_if": "",
"halt_if_type": "str",
"halt_if_compare": "is",
"entity_id": "climate.schlafzimmer_2",
"state_type": "str",
"blockInputOverrides": false,
"property": "payload",
"propertyType": "msg",
"value": "",
"valueType": "entityState"
"property": "data",
"value": "",
"valueType": "entity"
"for": "0",
"forType": "num",
"forUnits": "minutes",
"override_topic": false,
"state_location": "payload",
"override_payload": "msg",
"entity_location": "data",
"override_data": "msg",
"x": 840,
"y": 435,
"470a7259b1705568"
"id": "ddf3599b80f08a1e",
"type": "switch",
"name": "climate state before",
"property": "climate_state_before",
"propertyType": "flow",
"rules": [
"t": "eq",
"v": "dry",
"vt": "jsonata"
"t": "eq",
"v": "cool",
"vt": "jsonata"
"t": "eq",
"v": "heat",
"vt": "jsonata"
"t": "eq",
"v": "heat_cool",
"vt": "jsonata"
"t": "eq",
"v": "fan_only",
"vt": "jsonata"
"t": "eq",
"v": "off",
"vt": "jsonata"
"checkall": "true",
"repair": false,
"outputs": 6,
"x": 1380,
"y": 375,
"0e1960f6671ea943"
"0e1960f6671ea943"
"0e1960f6671ea943"
"0e1960f6671ea943"
"0e1960f6671ea943"
"0e1960f6671ea943"
"id": "13a90ccbaa9aeb7c",
"type": "change",
"rules": [
"t": "set",
"pt": "flow",
"to": "payload",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1130,
"y": 375,
"ddf3599b80f08a1e"
"id": "9f0f62575467ed4d",
"version": 3,
"outputs": 1,
"halt_if": "",
"value": "",
"property": "data",
"value": "",
"for": "0",
"forType": "num",
"x": 835,
"y": 375,
"13a90ccbaa9aeb7c"
"id": "5569d4be19f0d116",
"type": "switch",
"name": "closed/open",
"rules": [
"t": "eq",
"v": "true",
"vt": "jsonata"
"t": "eq",
"v": "false",
"vt": "jsonata"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 535,
"y": 405,
"9f0f62575467ed4d"
"bdcb58795f5e7b70"
"id": "30a66f6407b77831",
"type": "mqtt in",
"name": "Schlafzimmersensor",
"topic": "zigbee2mqtt/Schlafzimmerfenster rechts",
"qos": "2",
"datatype": "json",
"broker": "b496b411.fe5358",
"nl": false,
"rap": true,
"rh": 0,
"inputs": 0,
"x": 155,
"y": 405,
"c51b1d3eeaa4c37f"
"id": "c51b1d3eeaa4c37f",
"type": "change",
"name": "closed/opened",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "payload.contact",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 355,
"y": 405,
"5569d4be19f0d116"
"id": "42c5021e.042e7c",
"type": "server",
"name": "Home Assistant",
"version": 5,
"addon": false,
"rejectUnauthorizedCerts": true,
"ha_boolean": "y|yes|true|on|home|open",
"connectionDelay": true,
"cacheJson": true,
"heartbeat": false,
"heartbeatInterval": "30",
"areaSelector": "friendlyName",
"deviceSelector": "friendlyName",
"entitySelector": "friendlyName",
"statusSeparator": "at: ",
"statusYear": "hidden",
"statusMonth": "short",
"statusDay": "numeric",
"statusHourCycle": "h23",
"statusTimeFormat": "h:m",
"enableGlobalContextStore": true
"id": "b496b411.fe5358",
"type": "mqtt-broker",
"name": "MQTT",
"broker": "192.168.0.2",
"port": "1883",
"clientid": "",
"autoConnect": true,
"usetls": false,
"protocolVersion": "4",
"keepalive": "60",
"cleansession": true,
"birthTopic": "",
"birthQos": "0",
"birthPayload": "",
"birthMsg": {},
"closeTopic": "",
"closeQos": "0",
"closePayload": "",
"closeMsg": {},
"willTopic": "",
"willQos": "0",
"willPayload": "",
"willMsg": {},
"sessionExpiry": ""
(I didn't test the flow up to now so there could be an error in it...)
The problem with this is, that I would need several flow variables (hvac_modes, fan_modes, preset_modes...) and I though that there might be a simpler solution... Do you have any advise for me?
Thanks!
BR
