How to send command to Arduino through serial commend?
I want to use Node-RED: inject node to send commands to Arduino, Below is the code I wrote, but it did not work. Does anyone know how to write? Thank you.
void messageReceived () {
   if (payload = 0)
     Serial.println("open");
     digitalWrite(pump_in1_sol_A, HIGH);
     digitalWrite(pump_in2_sol_A, LOW);
   else if (payload = 1)
     Serial.println("closed");
     digitalWrite(pump_in1_sol_A, LOW);
Does the code you posted run on the Arduino?
The statement if (payload = 0) looks wrong. You are assigning a value to payload, not testing the current value.
There is a Serial i/o node which sends msg.payload to the serial port. Are you using that?
Untitled 1
@51fei
You should go read this: if - Arduino Reference
Should be:
if (payload == 0)
not
if (payload = 0)
Thank you, I had solved the problem.
