my goal is to get an request from mqtt to extend the cylinder (created in SVG), in the template block, when the cylinder is extended, it must send a data to MQTT. But I actually don't know how to set an output there.
I tried with $scope.msg.action, $scope.msg.payload, but still, the function block after the template block can't recognize the data I filled in the template.
How template looks like:
What do I need to write here to write stuffs from template into mqtt block?
Thank you!
Sincerely
