How to show an image from local directory in dashboard
the problem should be simple: I have a camera that every second save (OVERWRITE) an image in a local folder (/home/user/image.jpg). I simply would like to show this image in the dashboard periodically (every 10 seconds for example). I have no control on the camera.
Thank you very much in advance.
LP
This has come up many times. Have you tried searching the forum where you will find several threads which contain the answer
