Hello, I have a node "http request" in which I send certain numbers and it returns an image in jpg format..
I would like to know if there is a way to see this image on the dashboard? Thank you
try here.
Yes, but every time I make a request it is changed according to the image that corresponds to a certain code, it is not saved (I suppose), I just want it to be able to be seen on the dashboard
It would help if you share the part of code generating an image. someone with expertise in this area would help.
you can try saving the image by write file node and then use that file to show on dashboard may be?
