How to Stop a function node from execution its following code?
Heya,
I want to stop a function node from executing its code if a payload is f.e. not a number.
Is there anything like "node.stop" or "node.break"?
I can't filter this in a node beforehand because there are more messages from other MQTT devices are going into.
Thank you in advance.
Look for Q-gate in the library!
Opera Snapshot_2021-01-09_094629_discourse.nodered.org
@ghayne thank you, but I think for just this "small feature" I don't wanna add a new package/plugin.
If nothing is available for just "stopping" a function node from executing its code I will return a message with just "null". Thougth there would be an "recommended" way then doing this
Returning null does exactly that. Nothing is passed on. That is the recommended method.
if ( isNaN(msg.payload)) { return null; }
haha, thank you :smiley:
