I have seen alot of historical posts here about creating and automating flow backups, but nothing about stopping it from being generated.
Can someone please clarify when a flow.backup is created in Node-Red? Does it happen automatically in anyway or is it generated only after you press the deploy button?
If you want to prevent tampering of the flow then I assume you lockdown Node-Red using $node-red-admin hash-pw but then you must also manually delete the flow.backup file and this will not be generated again?
