How to store and fetch data from CouchDB with user password
Hi
was looking into the forum but did not find a documentation fetching data from couchdb.
Anyone having a goog example / tutorial ?
Thanks T
Did you look in the Flows tab of the forum?
Library - Node-RED
The IBM Cloudant DB is CouchDB compatible I believe which is why most of the nodes are for Cloudant but they should still work with CouchDB.
Comparing Apache CouchDB and IBM Cloudant
Ok thanks, will check
yes I did and installed couchdb, but no example available
will check with cloudant
Actually, you prompted me to get started on something that I've been meaning to get to for quite a long time, a PouchDB node.
Watch out for the initial announcement. The basics are working as a proof-of-concept already.
You will be able to use that to sync data with CouchDB as soon as I've added a few more features. PouchDB is compatible with CouchDB and its derivatives. It handles the data locally with the option to sync to a server.
