PouchDB is something that I keep meaning to do something with. I like the idea of it and it sync's up nicely with CouchDB which is a useful document-based nosql database that I've used previously since it is very JavaScript focused.
@akhtar321h, if the node isn't working for you, the alternative would be to:
cd ~/.node-red && npm install pouchdb- add a
pouchdb: require('pouchdb'),to the globals section of yoursettings.jsfile - Add a function node
- In the function node, add
const PouchDB = global.get('pouchdb');to the start
From there, you can use the example code from the PouchDB website.
