Hi all, I found this flow on the net and adapted it. The part that receives the text message works perfectly, while the part that receives the audio doesn't, I wanted the audio received, in .oga format, to be directly converted and then played by my vto. What am I doing wrong? Thank you.
[{"id":"1b09da8f0822414c","type":"tab","label":"Telegram legge il testo del bot","disabled":false,"info":"","env":[]},{"id":"66fac65b9f255c2b","type":"http request","z":"1b09da8f0822414c","name":"HTTP Request to Doorbell","method":"PUT","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.111/cgi-bin/audio.cgi?action=postAudio&httptype=singlepart&channel=1","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"basic","senderr":false,"headers":[],"x":980,"y":560,"wires":[[]]},{"id":"01496b2029831626","type":"telegram receiver","z":"1b09da8f0822414c","name":"","bot":"35f43d5f7e1032c3","saveDataDir":"","filterCommands":false,"x":110,"y":220,"wires":[["907d197834c48248","c449c2abcc3dd37b"],[]]},{"id":"8b280b44d6305844","type":"change","z":"1b09da8f0822414c","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.content","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":580,"y":200,"wires":[["1ea2580b.913478"]]},{"id":"a9292bc3e3b8853d","type":"ttsultimate","z":"1b09da8f0822414c","name":"","voice":"it-IT","ssml":false,"sonosipaddress":"192.168.1.158","sonosvolume":"75","sonoshailing":"0","config":"e05dc2be35faa69b","property":"payload","propertyType":{},"rules":[],"playertype":"noplayer","speakingrate":"1","speakingpitch":"0","unmuteIfMuted":true,"x":530,"y":400,"wires":[["3575dc1db9165504","3c06927b352e6a99"],[]]},{"id":"75a9fe0974a682a7","type":"function","z":"1b09da8f0822414c","name":"Parse Filename","func":"msg.filename = String(msg.filesArray[0].file);\nconst ffmpegIn = String(msg.filename);\nconst ffmpegOut = ffmpegIn.split('.').slice(0, -1).join('.');\nconst ffmpeg = \"-y -i \" + ffmpegIn +\" -c:a pcm_alaw -ac 1 -ar 8000 -sample_fmt s16 \" + ffmpegOut + \".wav\";\nmsg.ffmpegIn = ffmpegIn;\nmsg.ffmpegOut = ffmpegOut;\nmsg.ffmpeg = ffmpeg;\nmsg.filename = msg.ffmpegOut+\".wav\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":900,"y":480,"wires":[["fb2029e2b6613325","709cce66ed74f220"]]},{"id":"fb2029e2b6613325","type":"exec","z":"1b09da8f0822414c","command":"/usr/bin/ffmpeg","addpay":"ffmpeg","append":"","useSpawn":"false","timer":"15","winHide":false,"oldrc":false,"name":"Convert Audio","x":1100,"y":480,"wires":[["8088f134238662ea"],[],[]]},{"id":"383c7b0d5210da42","type":"function","z":"1b09da8f0822414c","name":"Build http payload","func":"msg.headers = {};\nmsg.headers['Content-Length'] = \"9999999\"\nmsg.headers['Content-Type'] = \"Audio/G.711A\"\nmsg.headers['User-Agent'] = \"NodeRed\"\nmsg.requestTimeout = 5000\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":650,"y":560,"wires":[["66fac65b9f255c2b"]]},{"id":"8088f134238662ea","type":"file in","z":"1b09da8f0822414c","name":"Read Converted File","filename":"filename","filenameType":"msg","format":"","chunk":false,"sendError":false,"allProps":false,"x":400,"y":560,"wires":[["383c7b0d5210da42"]]},{"id":"3575dc1db9165504","type":"switch","z":"1b09da8f0822414c","name":"Finished Processing","property":"payload","propertyType":"msg","rules":[{"t":"true"}],"checkall":"true","repair":false,"outputs":1,"x":740,"y":400,"wires":[["75a9fe0974a682a7"]]},{"id":"85acd2f01fdf1618","type":"link in","z":"1b09da8f0822414c","name":"TTS VTO","links":["1d740cd4495e90ea","d3ba7455514dbb78"],"x":595,"y":140,"wires":[["1ea2580b.913478"]]},{"id":"1ea2580b.913478","type":"function","z":"1b09da8f0822414c","name":"Command remover /","func":"// This function processes the incoming text and tries to determine if it is a \n// specific \"single word\" command like the ones below in the list or\n// other free English commands like \"turn on the garden light\"\n\n// These are the commands (\"reserved words\") that execute a function without parameters\nvar commands = [\"help\",\"camera\",\"me\",\"userlist\",\"loglevel\",\"logmute\",\"weather\",\"youtube\",\"solar\",\"miflora\",\"systeminfo\",\"rain\"];\n\nvar temp = msg.payload;\n\n\n\n// removing rubbish\n//temp = temp.replace(\"\",\"\");\n\n\n\n\n// se è un comando lo annullo\nif (temp.indexOf(\"/\")>-1) {\n msg = \"\";\n}\n\n\nreturn msg;","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":820,"y":220,"wires":[["a9292bc3e3b8853d"],[]]},{"id":"c44c702c5ae1e10b","type":"change","z":"1b09da8f0822414c","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":220,"y":460,"wires":[[]]},{"id":"907d197834c48248","type":"switch","z":"1b09da8f0822414c","name":"","property":"payload.type","propertyType":"msg","rules":[{"t":"eq","v":"voice","vt":"str"},{"t":"eq","v":"message","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":290,"y":220,"wires":[["4747f8bc1b12a1a8"],["8b280b44d6305844"]]},{"id":"c449c2abcc3dd37b","type":"debug","z":"1b09da8f0822414c","name":"debug 11","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":320,"y":320,"wires":[]},{"id":"dbb6d173449d8fcf","type":"debug","z":"1b09da8f0822414c","name":"debug 12","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1520,"y":260,"wires":[]},{"id":"709cce66ed74f220","type":"debug","z":"1b09da8f0822414c","name":"debug 13","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":940,"y":720,"wires":[]},{"id":"3c06927b352e6a99","type":"debug","z":"1b09da8f0822414c","name":"debug 14","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":900,"y":340,"wires":[]},{"id":"af689a244cf2fe43","type":"function","z":"1b09da8f0822414c","name":"Parse Filename","func":"msg.filename = \"prova.wav\";\nconst ffmpegIn = String(msg.filename);\nconst ffmpegOut = ffmpegIn.split('.').slice(0, -1).join('.');\nconst ffmpeg = \"-y -i \" + ffmpegIn +\" -c:a pcm_alaw -ac 1 -ar 8000 -sample_fmt s16 \" + ffmpegOut + \".wav\";\nmsg.ffmpegIn = ffmpegIn;\nmsg.ffmpegOut = ffmpegOut;\nmsg.ffmpeg = ffmpeg;\nmsg.filename = msg.ffmpegOut+\".wav\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1200,"y":360,"wires":[["fb2029e2b6613325"]]},{"id":"4747f8bc1b12a1a8","type":"change","z":"1b09da8f0822414c","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.content.filename","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":540,"y":280,"wires":[["75a9fe0974a682a7"]]},{"id":"35f43d5f7e1032c3","type":"telegram bot","botname":"HomeAssistantBot","usernames":"","chatids":"","baseapiurl":"","updatemode":"polling","pollinterval":"300","usesocks":false,"sockshost":"","socksprotocol":"socks5","socksport":"6667","socksusername":"anonymous","sockspassword":"","bothost":"","botpath":"","localbotport":"8443","publicbotport":"8443","privatekey":"","certificate":"","useselfsignedcertificate":false,"sslterminated":false,"verboselogging":false},{"id":"e05dc2be35faa69b","type":"ttsultimate-config","name":"TTS Service","noderedipaddress":"192.168.1.138","noderedport":"1980","purgediratrestart":"purge","ttsservice":"googletranslate","TTSRootFolderPath":""}]
TypeError: Cannot read properties of undefined (reading '0')
