How to turn off script in certain hours
I have set up an ac that reacts to temperature sensor data coming from a python script. Can you please guide me on how to turn off ac automatically after 7 pm? Also, how can I run the python script at a certain time like from 6 am to 7 pm? I have added my current flow. Your help will be greatly appreciated. Thank you :slight_smile:
        "id": "0a5f190822b330f1",
        "type": "tab",
        "label": "Flow 1",
        "disabled": false,
        "info": "",
        "env": []
        "id": "b3cba65475e17eb1",
        "type": "rbe",
        "z": "0a5f190822b330f1",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": true,
        "property": "payload",
        "topi": "topic",
        "x": 1420,
        "y": 1040,
                "2ca43eb7563c07f2"
        "id": "2ca43eb7563c07f2",
        "type": "switch",
        "propertyType": "msg",
        "rules": [
                "t": "true"
                "t": "else"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 1550,
        "y": 1040,
                "85be91facbaac711"
                "7ba58268ded90e6f"
        "id": "85be91facbaac711",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "[{\"topic\":\"power\",\"payload\":\"on\"},{\"topic\":\"mode\",\"payload\":\"cool\"}]",
                "tot": "json"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1760,
        "y": 980,
                "e69c3e5a157c1679"
        "id": "7ba58268ded90e6f",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "[{\"topic\":\"power\",\"payload\":\"off\"}]",
                "tot": "json"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1760,
        "y": 1040,
                "e69c3e5a157c1679"
        "id": "e69c3e5a157c1679",
        "type": "split",
        "splt": "\\n",
        "spltType": "str",
        "arraySplt": 1,
        "arraySpltType": "len",
        "stream": false,
        "addname": "",
        "x": 1990,
        "y": 1020,
                "732f1b1e89a3e7d5"
        "id": "732f1b1e89a3e7d5",
        "type": "delay",
        "pauseType": "rate",
        "timeout": "5",
        "timeoutUnits": "seconds",
        "rate": "1",
        "nbRateUnits": "1",
        "rateUnits": "second",
        "randomFirst": "1",
        "randomLast": "5",
        "randomUnits": "seconds",
        "drop": false,
        "outputs": 1,
        "x": 1290,
        "y": 1140,
                "fde8db8c7fa6e9ae"
        "id": "fde8db8c7fa6e9ae",
        "type": "change",
        "rules": [
                "t": "move",
                "p": "payload.topic",
                "pt": "msg",
                "to": "topic",
                "tot": "msg"
                "t": "move",
                "p": "payload.payload",
                "pt": "msg",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1510,
        "y": 1140,
                "2aff020d0e115066"
        "id": "2aff020d0e115066",
        "type": "rbe",
        "func": "rbe",
        "gap": "",
        "start": "",
        "inout": "out",
        "septopics": true,
        "x": 650,
        "y": 880,
                "f8a64bda2398f4e4",
                "d32bc1fdbdb31516"
        "id": "aee76045468e8fd0",
        "type": "ui_dropdown",
        "label": "Vertical swing ",
        "tooltip": "",
        "place": "Select option",
        "group": "5c569ec8.d608f",
        "order": 6,
        "width": 0,
        "height": 0,
        "passthru": false,
        "multiple": false,
        "options": [
                "label": "Default",
                "value": "default",
                "type": "str"
                "label": "Swing in full range",
                "value": "full",
                "type": "str"
                "label": "Fixed top",
                "value": "fixedTop",
                "type": "str"
                "label": "Fixed mid-top",
                "value": "fixedMidTop",
                "type": "str"
                "label": "Fixed mid",
                "value": "fixedMid",
                "type": "str"
                "label": "Fixed mid-bottom",
                "value": "fixedMidBottom",
                "type": "str"
                "label": "Fixed bottom",
                "value": "fixedBottom",
                "type": "str"
                "label": "Swing bottom",
                "value": "swingBottom",
                "type": "str"
                "label": "Swing mid-bottom",
                "value": "swingMidBottom",
                "type": "str"
                "label": "Swing mid",
                "value": "swingMid",
                "type": "str"
                "label": "Swing mid top",
                "value": "swingMidTop",
                "type": "str"
                "label": "Swing top",
                "value": "swingTop",
                "type": "str"
        "payload": "",
        "topic": "swingVert",
        "topicType": "str",
        "className": "",
        "x": 440,
        "y": 460,
                "2aff020d0e115066"
        "id": "6a82621380e24614",
        "label": "Horizontal swing ",
        "tooltip": "",
        "order": 5,
        "width": 0,
        "height": 0,
        "passthru": false,
        "multiple": false,
        "options": [
                "label": "Default",
                "value": "default",
                "type": "str"
                "label": "Full",
                "value": "full",
                "type": "str"
                "label": "Fixed left",
                "value": "fixedLeft",
                "type": "str"
                "label": "Fixed mid-left",
                "value": "fixedMidLeft",
                "type": "str"
                "type": "str"
                "label": "Fixed mid-right",
                "value": "fixedMidRight",
                "type": "str"
                "label": "Fixed right",
                "value": "fixedRight",
                "type": "str"
                "label": "Full alt",
                "value": "fullAlt",
                "type": "str"
        "payload": "",
        "topic": "swingHor",
        "topicType": "str",
        "className": "",
        "x": 440,
        "y": 520,
                "2aff020d0e115066"
        "info": "Controls the swing mode of the horizontal air blades (not available on all units)"
        "id": "80f433b87f4776ac",
        "label": "Fan speed",
        "tooltip": "",
        "order": 4,
        "width": 0,
        "height": 0,
        "passthru": false,
        "multiple": false,
        "options": [
                "label": "Auto",
                "value": "auto",
                "type": "str"
                "label": "Low",
                "value": "low",
                "type": "str"
                "label": "Medium low",
                "value": "mediumLow",
                "type": "str"
                "label": "Medium",
                "value": "medium",
                "type": "str"
                "label": "Medium high",
                "value": "mediumHigh",
                "type": "str"
                "label": "High",
                "value": "high",
                "type": "str"
        "payload": "",
        "topic": "fanSpeed",
        "topicType": "str",
        "className": "",
        "x": 430,
        "y": 400,
                "2aff020d0e115066"
        "id": "5d7b2dda548ea6bb",
        "label": "Mode",
        "tooltip": "",
        "order": 3,
        "width": "0",
        "height": "0",
        "passthru": false,
        "multiple": false,
        "options": [
                "label": "Auto",
                "value": "auto",
                "type": "str"
                "label": "Cool",
                "value": "cool",
                "type": "str"
                "label": "Dry",
                "value": "dry",
                "type": "str"
                "label": "Fan only",
                "value": "fan_only",
                "type": "str"
                "label": "Heat",
                "value": "heat",
                "type": "str"
        "payload": "",
        "topic": "mode",
        "topicType": "str",
        "className": "",
        "x": 430,
        "y": 240,
                "2aff020d0e115066"
        "id": "2c3803e175c14299",
        "type": "ui_switch",
        "label": "Power",
        "tooltip": "",
        "order": 1,
        "width": "0",
        "height": "0",
        "passthru": false,
        "decouple": "true",
        "topic": "power",
        "topicType": "str",
        "style": "",
        "onvalue": "on",
        "onvalueType": "str",
        "onicon": "",
        "oncolor": "",
        "offvalue": "off",
        "offvalueType": "str",
        "officon": "",
        "offcolor": "",
        "animate": true,
        "className": "",
        "x": 430,
        "y": 160,
                "2aff020d0e115066"
        "id": "e034be5020e5165c",
        "label": "Lights",
        "tooltip": "",
        "order": 9,
        "width": "3",
        "height": "1",
        "passthru": false,
        "decouple": "true",
        "topic": "lights",
        "topicType": "str",
        "style": "",
        "onvalue": "on",
        "onicon": "",
        "oncolor": "",
        "offvalue": "off",
        "officon": "",
        "offcolor": "",
        "animate": true,
        "className": "",
        "x": 410,
        "y": 700,
                "2aff020d0e115066"
        "id": "58a6ca227f255b65",
        "label": "Power save",
        "tooltip": "",
        "order": 10,
        "width": "3",
        "height": "1",
        "passthru": false,
        "decouple": "true",
        "topic": "powerSave",
        "topicType": "str",
        "style": "",
        "onvalue": "on",
        "onicon": "",
        "oncolor": "",
        "offvalue": "off",
        "officon": "",
        "offcolor": "",
        "animate": true,
        "className": "",
        "x": 430,
        "y": 760,
                "2aff020d0e115066"
        "id": "85c6129db8fc0c16",
        "label": "Cold plasma",
        "tooltip": "",
        "order": 7,
        "width": "3",
        "height": "1",
        "passthru": false,
        "decouple": "true",
        "topic": "health",
        "topicType": "str",
        "style": "",
        "onvalue": "on",
        "onicon": "",
        "oncolor": "",
        "offvalue": "off",
        "officon": "",
        "offcolor": "",
        "animate": true,
        "className": "",
        "x": 430,
        "y": 580,
                "2aff020d0e115066"
        "id": "867709092587f839",
        "label": "X-Fan",
        "tooltip": "",
        "order": 8,
        "width": "3",
        "height": "1",
        "passthru": false,
        "decouple": "true",
        "topic": "blow",
        "topicType": "str",
        "style": "",
        "onvalue": "on",
        "onicon": "",
        "oncolor": "",
        "offvalue": "off",
        "officon": "",
        "offcolor": "",
        "animate": true,
        "className": "",
        "x": 410,
        "y": 640,
                "2aff020d0e115066"
        "id": "19785ce509b23596",
        "type": "ui_numeric",
        "label": "Temperature",
        "tooltip": "",
        "order": 2,
        "width": 0,
        "height": 0,
        "wrap": false,
        "passthru": false,
        "topic": "temperature",
        "topicType": "str",
        "format": "{{value}}",
        "min": "23",
        "max": "25",
        "step": 1,
        "className": "",
        "x": 430,
        "y": 320,
                "2aff020d0e115066"
        "id": "f8a64bda2398f4e4",
        "type": "gree-hvac",
        "name": "AC-Room 1",
        "device": "fb5f648e10ccac25",
        "interval": "1",
        "debug": false,
        "x": 80,
        "y": 820,
                "d32bc1fdbdb31516"
                "9c39fbfb4a69841d",
                "d32bc1fdbdb31516"
        "info": "const Gree = require('gree-hvac-client');\r\n\r\nmodule.exports = function (RED) {\r\n    function GreeHvacNode(config) {\r\n        RED.nodes.createNode(this, config);\r\n        const node = this;\r\n        const device = RED.nodes.getNode(config.device);\r\n\r\n        node.status({});\r\n\r\n        const pollingInterval = config.interval * 1000;\r\n        let client = new Gree.Client({\r\n            host: device.host,\r\n            pollingInterval: pollingInterval,\r\n            pollingTimeout: pollingInterval / 2,\r\n            debug: config.debug\r\n        });\r\n\r\n        const statusConnected = () => {\r\n            node.status({fill: 'green', shape: 'dot', text: 'connected to ' + client.getDeviceId()})\r\n        };\r\n\r\n        const statusConnecting = () => node.status({fill: 'yellow', shape: 'dot', text: 'connecting...'});\r\n        const statusNoResponse = () => node.status({fill: 'yellow', shape: 'dot', text: 'no response...'});\r\n\r\n        statusConnecting();\r\n\r\n        client.on('connect', statusConnected);\r\n        client.on('update', (updatedProperties, properties) => {\r\n            statusConnected();\r\n            node.send([{\r\n                topic: 'updated',\r\n                payload: updatedProperties\r\n            }, {\r\n                topic: 'properties',\r\n                payload: properties\r\n            }]);\r\n        });\r\n        client.on('success', (updatedProperties, properties) => {\r\n            node.send([{\r\n                topic: 'acknowledged',\r\n                payload: updatedProperties\r\n            }, {\r\n                topic: 'properties',\r\n                payload: properties\r\n            }]);\r\n        });\r\n        client.on('disconnect', statusConnecting);\r\n        client.on('no_response', statusNoResponse);\r\n\r\n        this.on('input', function (msg) {\r\n            if (typeof msg.payload === \"object\")\r\n                client.setProperties(msg.payload);\r\n            else\r\n                client.setProperty(msg.topic, msg.payload);\r\n        });\r\n\r\n        this.on('close', function () {\r\n            client.disconnect();\r\n            client = null;\r\n        });\r\n    }\r\n\r\n    RED.nodes.registerType('gree-hvac', GreeHvacNode);\r\n};"
        "id": "d32bc1fdbdb31516",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "x": 330,
        "y": 880,
        "id": "059a0e3b08b8e980",
        "type": "switch",
        "property": "topic",
        "rules": [
                "t": "eq",
                "v": "power",
                "vt": "str"
                "t": "eq",
                "v": "mode",
                "vt": "str"
                "t": "eq",
                "v": "temperature",
                "vt": "str"
                "t": "eq",
                "v": "fanSpeed",
                "vt": "str"
                "t": "eq",
                "v": "swingVert",
                "vt": "str"
                "t": "eq",
                "v": "swingHor",
                "vt": "str"
                "t": "eq",
                "v": "health",
                "vt": "str"
                "t": "eq",
                "v": "blow",
                "vt": "str"
                "t": "eq",
                "v": "lights",
                "vt": "str"
                "t": "eq",
                "v": "powerSave",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 10,
        "x": 210,
        "y": 640,
                "2c3803e175c14299"
                "5d7b2dda548ea6bb"
                "19785ce509b23596"
                "80f433b87f4776ac"
                "aee76045468e8fd0"
                "6a82621380e24614"
                "85c6129db8fc0c16"
                "867709092587f839"
                "e034be5020e5165c"
                "58a6ca227f255b65"
        "id": "9c39fbfb4a69841d",
        "type": "split",
        "splt": "\\n",
        "spltType": "str",
        "arraySplt": 1,
        "stream": false,
        "addname": "topic",
        "x": 70,
        "y": 640,
                "059a0e3b08b8e980"
        "id": "83da7ce6e9941a15",
        "type": "pythonshell in",
        "pyfile": "/home/pi3/Desktop/ac.py",
        "virtualenv": "",
        "continuous": true,
        "stdInData": false,
        "x": 860,
        "y": 640,
                "af0e7678ad437da6"
        "id": "2e20212159b0a6db",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 1570,
        "y": 600,
        "id": "a27724f700ed4dd0",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "$number(payload)",
                "tot": "jsonata"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1300,
        "y": 640,
                "2e20212159b0a6db",
                "0cbe4728813c94f4"
        "id": "af0e7678ad437da6",
        "type": "function",
        "func": "msg.payload= msg.payload.replace(/\\n/, \"\");\nreturn msg;\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1080,
        "y": 640,
                "a27724f700ed4dd0"
        "id": "0cbe4728813c94f4",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "$$.payload > 26 ? true : false",
                "tot": "jsonata"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1580,
        "y": 760,
                "b3cba65475e17eb1"
        "id": "2aafb87171bc9011",
        "type": "comment",
        "name": "Set Temperature to turn on/off",
        "info": "",
        "x": 1620,
        "y": 700,
        "id": "5c569ec8.d608f",
        "type": "ui_group",
        "name": "AC",
        "tab": "168c092a.469d97",
        "order": 1,
        "disp": true,
        "width": "6",
        "collapse": false
        "id": "fb5f648e10ccac25",
        "type": "gree-hvac-config",
        "name": "AC",
        "host": "192.168.0.2"
        "id": "168c092a.469d97",
        "type": "ui_tab",
        "name": "Home",
        "icon": "dashboard",
        "disabled": false,
        "hidden": false
Have a look at node-red-contrib-cron-plus. It is widely recognised as the most powerful scheduler.
Looking at your script it looks like you already have the exec nodes working to turn the unit on and off etc
As Colin says you can use any of the scheduling nodes to then send an off command at a certain time (and Cron-plus is the best one of those)
Alternatively you can have the unit running continually and your flow can instead branch dependant on time of day and do something different (like turn off at 7PM) the difference being - that the Cronplus node will be configured to run (once) at 7PM and send the Off command - if someone then turns the unit back on it will continue to run - alternatviely if the command does not work (for whatever reason) then it will not be sent again and the unit will continue to run
If you look at the Within-time node from the within time · rdmtc/node-red-contrib-sun-position Wiki · GitHub
Then you can have a flow that runs continously and branches at (say 7PM-9PM) and does something different - such as turn off the AC or turn it up so it costs less to run in peak hour etc
Craig
Thanks Colin and Craig for your suggestions :slight_smile: I used the Within-time node and it's working completely fine.
Good work - if you can - post up your flow so others can see it if they are trying to solve a similar problem in the future - a good idea is to post a picture of what it looks like (warts and all !!)
and then paste up the JSON for others to learn from
Craig
