Runtime and waittime
Hi All.
So I hope that someone cleverer than me can help with optimising a flow that I'm working on (actually had it working, but the raspi memory card died and my backup was faulty)... Anyways, doing it second time, I hoped that someone here would provide help on a smarter way of going about it.
Basically, my flow(s) controls a series of vents in my basement, which dependent on different weather conditions will start.
I have previously done the on/off logic manually, but maybe there's a node or something that will help making it simpler.
The basic functionality is this:
I set a max runtime, and a minimumtime to wait between runs. If the weather conditions are within threshold, a true message will be received, which - if waittime is over - will start the vents running the set runtime.
Anyone knowledgeable of a cleverer way of achieving this than the rather complex way I'm doing it now?
        "id": "76c93132.4718e8",
        "type": "tab",
        "label": "On-Off logic",
        "disabled": false,
        "info": ""
        "id": "cc514a9c.f4c488",
        "type": "comment",
        "z": "76c93132.4718e8",
        "name": "GLOBAL HUMIDITY ON / OFF INPUT",
        "info": "",
        "x": 390,
        "y": 560,
        "id": "dce663bc.faf178",
        "type": "comment",
        "name": "PANEL INPUT",
        "info": "",
        "x": 250,
        "y": 1020,
        "id": "b3c4512f.f9f3d8",
        "type": "comment",
        "name": "TIMERS",
        "info": "",
        "x": 1060,
        "y": 900,
        "id": "7a6db23d.5a1f0c",
        "type": "inject",
        "repeat": "",
        "crontab": "",
        "once": true,
        "onceDelay": "",
        "topic": "",
        "payload": "60",
        "payloadType": "num",
        "x": 250,
        "y": 1140,
                "1f9d9a45.d46ff6"
        "id": "1f9d9a45.d46ff6",
        "type": "ui_numeric",
        "label": "setWaitTime (minutes)",
        "tooltip": "Time to wait between runs",
        "group": "962c32d6.8a7118",
        "order": 2,
        "width": 0,
        "height": 0,
        "wrap": false,
        "passthru": false,
        "topic": "",
        "topicType": "str",
        "format": "{{value}}",
        "min": "5",
        "max": "180",
        "step": "5",
        "className": "",
        "x": 460,
        "y": 1140,
                "b6840176.c22678",
                "18d8ccc6a9b681ae"
        "id": "dcd51979.16762",
        "label": "setRunTime (minutes)",
        "tooltip": "Maximum time to run fan",
        "order": 3,
        "width": 0,
        "height": 0,
        "passthru": false,
        "topic": "",
        "min": "5",
        "max": "180",
        "step": "5",
        "x": 460,
        "y": 1200,
                "cb15852b.67ba6"
        "id": "7a7b44ad.970bb4",
        "type": "inject",
        "repeat": "",
        "crontab": "",
        "once": true,
        "onceDelay": "",
        "topic": "",
        "payload": "15",
        "x": 250,
        "y": 1200,
                "dcd51979.16762"
        "id": "dacc0ddd.1fc6d",
        "type": "comment",
        "name": "PANEL OUTPUT",
        "info": "",
        "x": 1460,
        "y": 320,
        "id": "b6840176.c22678",
        "type": "function",
        "name": "Set Timer (later to be Minutes*60)",
        "func": "global.set(\"setWaitTime\", msg.payload * 60); // seconds to minutes\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 744.9999694824219,
        "y": 1141.6666707992554,
                "2142d13bd7ca8396"
        "id": "cb15852b.67ba6",
        "type": "function",
        "func": "global.set('setRunTime', msg.payload * 60); // seconds to minutes\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "y": 1196.666714668274,
        "id": "a2b3e6a3.ab355",
        "type": "mytimeout",
        "name": "timerWait",
        "outtopic": "timerWait",
        "outsafe": "on",
        "outwarning": "",
        "outunsafe": "off",
        "warning": "0",
        "timer": "6",
        "debug": false,
        "ndebug": false,
        "ignoreCase": false,
        "repeat": false,
        "again": false,
        "x": 1240,
        "y": 1000,
                "9d703ea6.447f3"
                "1f972648.38551a"
        "id": "ff2c7ded.225eb8",
        "type": "switch",
        "name": "True/False",
        "property": "payload",
        "propertyType": "msg",
        "rules": [
                "t": "true"
                "t": "false"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 848.0000610351562,
        "y": 1004,
                "98bb52b9.e51dd8"
                "4bd91ae.cf4e064"
        "id": "b1cd4a8b.5790c",
        "type": "dsm",
        "name": "Main",
        "sm_config": "{\n    \"currentState\": \"undefined\",\n    \"data\": {\n        \"timerWait\": false,\n        \"timerRun\": false,\n        \"toggle_Ah\": false,\n        \"toggle_Manual\": false\n    },\n    \"methods\": {\n        \n        \"timerWait\": \"sm.data.timerWait = msg.payload;\",\n        \"timerRun\": \"sm.data.timerRun = msg.payload;\",\n        \"toggle_Ah\": \"sm.data.toggle_Ah = msg.payload;\",\n        \"toggle_Manual\": \"sm.data.toggle_Manual = msg.payload;\",\n        \"onTransition\": [\n            \"if (sm.data.toggle_Manual && sm.data.timerRun)  {\",\n            \"   sm.currentState = true;\",\n            \"   sm.fill = 'green';\",\n            \"} else if (sm.data.toggle_Ah && sm.data.timerRun) {\",\n            \"   sm.currentState = true;\",\n            \"   sm.fill = 'green';\",\n            \"} else {\",\n            \"   sm.currentState = false;\",\n            \"   sm.fill = 'yellow';\",\n            \"}\",\n            \"msg.payload = sm.currentState;\",\n            \"output = true;\"\n        ],\n        \"status\": {\n            \"fill\": {\n                \"get\": \"sm.fill;\"\n            },\n            \"shape\": \"dot\",\n            \"text\": {\n                \"get\": \"sm.currentState;\"\n            }\n        }\n    }\n}",
        "x": 980,
        "y": 720,
                "c9ff195a.e69488",
                "f9c92daf.18aca",
                "5c3d708d.9cd15",
                "82883970.177018"
        "id": "a9f27c07.0ca5b8",
        "type": "function",
        "name": "renamer",
        "func": "msg.topic = \"timerRun\"\nmsg.name = \"timerRun\"\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 1400,
        "y": 940,
                "b1cd4a8b.5790c",
                "816f6bca.6fc118",
                "ff2c7ded.225eb8"
        "id": "b233db1a.03ac08",
        "type": "switch",
        "rules": [
                "t": "true"
                "t": "false"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 730,
        "y": 720,
                "b1cd4a8b.5790c",
                "b76a2377.ca56b"
        "id": "c9ff195a.e69488",
        "type": "function",
        "name": "Test",
        "func": "msg.color = (msg.payload === true)?\"red\":\"grey\";\nmsg.topic = (msg.payload === true)?\n\"fa fa-chrome fa-spin fa-2x fa-fw\":\"fa fa-chrome fa-2x\";\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 1430,
        "y": 360,
                "ce486d38.3a2f6"
        "id": "4ec3d35e.d625f4",
        "type": "change",
        "rules": [
                "t": "change",
                "p": "payload",
                "pt": "msg",
                "from": "on",
                "fromt": "str",
                "to": "true",
                "tot": "bool"
                "t": "change",
                "p": "payload",
                "pt": "msg",
                "from": "off",
                "fromt": "str",
                "to": "false",
                "tot": "bool"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1220,
        "y": 940,
                "a9f27c07.0ca5b8"
        "id": "ede78103.079558",
        "type": "ui_button",
        "name": "toggle_Manual",
        "order": 1,
        "width": 0,
        "height": 0,
        "passthru": false,
        "label": "ON",
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "",
        "payload": "true",
        "payloadType": "bool",
        "topic": "toggle_Manual",
        "topicType": "str",
        "x": 260,
        "y": 1080,
                "b233db1a.03ac08"
        "id": "ce486d38.3a2f6",
        "type": "ui_text",
        "group": "74b09387.ec36dc",
        "order": 1,
        "width": "2",
        "height": "1",
        "label": "FAN",
        "format": "<font color={{msg.color}} ><i class=\"{{msg.topic}} \" style=\"font-size:2px;\"></i></font>",
        "layout": "row-spread",
        "x": 1570,
        "y": 360,
        "id": "5972b043.ae2db",
        "name": "timerRun",
        "outtopic": "timerRun",
        "outsafe": "on",
        "outwarning": "",
        "outunsafe": "off",
        "warning": "0",
        "timer": "3",
        "debug": false,
        "ndebug": false,
        "repeat": false,
        "again": false,
        "x": 1060,
        "y": 940,
                "4ec3d35e.d625f4"
                "f3e938d0.aef2a"
        "id": "b76a2377.ca56b",
        "type": "function",
        "name": "Get global time settings and timerRun gate ",
        "func": "// Need to change the on to\n// { \"payload\": \"on\", \"timeout\": 69, \"warning\": 10 }\n\nif(msg.payload === true) {\n    msg.payload = { \n        \"payload\": \"on\", \n        \"timeout\": global.get('setRunTime'),\n        \"warning\": 0\n    };\n} else {\n    msg.payload = {  \"payload\": \"off\" };\n}\n\n    if(msg.topic == \"toggle_Ah\" && (!global.get('timerRun') && !global.get('timerWait') === true)) \n    {\n    return msg;\n    }\n    if(msg.topic == \"toggle_Manual\" && !global.get('timerRun') === true) \n    {\n    return msg;\n    }\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 650,
        "y": 940,
                "5972b043.ae2db",
                "b8c9f632.f35548",
                "cbe89198.ae6a38"
        "id": "c0dfb87e.f22148",
        "type": "ui_text",
        "order": 3,
        "width": "0",
        "height": "0",
        "label": "REMAINING RUN TIME",
        "format": "{{msg.payload}}",
        "x": 1690,
        "y": 420,
        "id": "4609a9ea.533df8",
        "type": "ui_text",
        "order": 4,
        "width": "0",
        "height": "0",
        "label": "REMAINING WAIT TIME",
        "x": 1690,
        "y": 480,
        "id": "35a11ad.3fffce6",
        "type": "function",
        "name": "Test",
        "func": "msg.color = (msg.payload === true)?\"lime\":\"grey\";\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 1430,
        "y": 540,
                "c9e20497.c5ff58"
        "id": "c9e20497.c5ff58",
        "type": "ui_text",
        "order": 2,
        "width": "3",
        "height": "1",
        "label": "aH switch",
        "format": "<font color={{msg.color}} ><i class=\"fa fa-circle\" style=\"font-size:36px;\"></i></font>",
        "x": 1580,
        "y": 540,
        "id": "75294026.c3b3d",
        "type": "function",
        "name": "renamer",
        "func": "msg.topic = \"timerWait\"\nmsg.name = \"timerWait\"\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 1560,
        "y": 1000,
                "b1cd4a8b.5790c",
                "3d113495.28c70c"
        "id": "9d703ea6.447f3",
        "type": "change",
        "rules": [
                "t": "change",
                "p": "payload",
                "pt": "msg",
                "from": "on",
                "fromt": "str",
                "to": "true",
                "tot": "bool"
                "t": "change",
                "p": "payload",
                "pt": "msg",
                "from": "off",
                "fromt": "str",
                "to": "false",
                "tot": "bool"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1400,
        "y": 1000,
                "75294026.c3b3d"
        "id": "f3e938d0.aef2a",
        "type": "function",
        "name": "[s] to [hh:mm:ss]",
        "func": "// Message from preceeding node is in seconds - should be less than 24 hours (86400 seconds).\nvar time = (new Date(msg.payload * 1000)).toUTCString().match(/(\\d\\d:\\d\\d:\\d\\d)/)[0];\n// Pass on the string to the next node, what ever that may be. (groov Data Store for example).\nmsg.payload = time;\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 1460,
        "y": 420,
                "c0dfb87e.f22148"
        "id": "1f972648.38551a",
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "x": 1460,
        "y": 480,
                "4609a9ea.533df8"
        "id": "816f6bca.6fc118",
        "type": "function",
        "name": "global timerRun",
        "func": "global.set('timerRun', msg.payload); \nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 1580,
        "y": 940,
        "id": "3d113495.28c70c",
        "type": "function",
        "func": "global.set('timerWait', msg.payload); \nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 1720,
        "y": 1000,
        "id": "27150f18.7e4138",
        "type": "inject",
        "repeat": "",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "false",
        "x": 1430,
        "y": 1080,
                "3d113495.28c70c",
                "816f6bca.6fc118"
        "id": "98bb52b9.e51dd8",
        "type": "change",
        "name": "reset for manual",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "{ \"payload\": \"off\" }",
                "tot": "json"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1139.9999618530273,
        "y": 1068.3333745002747,
                "a2b3e6a3.ab355",
                "5cf5542b.864d3c"
        "id": "f72c0e11.a4efa",
        "type": "function",
        "name": "get global humOnOff",
        "func": "msg.payload = global.get(\"humOnOff\");\nmsg.topic = \"toggle_Ah\"\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 340,
        "y": 640,
                "b233db1a.03ac08",
                "35a11ad.3fffce6"
        "id": "f9efdf3f.9ae898",
        "type": "inject",
        "repeat": "1",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 310,
        "y": 600,
                "f72c0e11.a4efa"
        "id": "f9c92daf.18aca",
        "type": "Sonoff device",
        "mode": "0",
        "broker": "864c9ec1.9c208",
        "device": "sonoff",
        "name": "Sonoff switch",
        "onValue": "ON",
        "offValue": "OFF",
        "cmdPrefix": "cmnd",
        "statPrefix": "stat",
        "telePrefix": "tele",
        "x": 1250,
        "y": 720,
        "id": "5ab34a74.33d784",
        "type": "ui_chart",
        "group": "326cc72f.e0ba98",
        "order": 4,
        "width": "6",
        "height": "3",
        "label": "On/Off",
        "chartType": "line",
        "legend": "false",
        "xformat": "HH:mm:ss",
        "interpolate": "step",
        "nodata": "",
        "dot": false,
        "ymin": "0",
        "ymax": "20",
        "removeOlder": "8",
        "removeOlderPoints": "",
        "removeOlderUnit": "3600",
        "cutout": 0,
        "useOneColor": false,
        "colors": [
            "#ff2600",
            "#ff2600",
            "#ff2600",
            "#ff2600",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "x": 1716,
        "y": 642,
        "id": "5c3d708d.9cd15",
        "type": "function",
        "name": "graph_OnOff (bool to number)",
        "func": "var msg1 = {};\n\nif (msg.payload === true){\nmsg1.payload = 15;\nmsg1.topic = 'On/Off';\n}\nelse if (msg.payload === false) {\nmsg1.payload = 5;\nmsg1.topic = 'On/Off';\n}\n\nreturn msg1;",
        "outputs": 1,
        "noerr": 0,
        "x": 1468,
        "y": 648,
                "5ab34a74.33d784",
                "923835e9.4f59"
        "id": "923835e9.4f59",
        "type": "link out",
        "links": [
            "d718360b.e9e73"
        "x": 1680,
        "y": 696,
        "id": "82883970.177018",
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "x": 1051.6666666666665,
        "y": 621.6666666666666,
        "id": "6cda23b8.ef1eec",
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "x": 1203.333251953125,
        "y": 1362.9999389648438,
        "id": "5cf5542b.864d3c",
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "x": 1220,
        "y": 1163.333251953125,
        "id": "b8c9f632.f35548",
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "x": 1255,
        "y": 1216.6666259765625,
        "id": "cbe89198.ae6a38",
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "x": 938,
        "y": 832,
        "id": "4bd91ae.cf4e064",
        "type": "function",
        "name": "Get setWaitTime",
        "func": "var msg1  = {};\n\nif(msg.payload === false) \n{\n    msg1.payload = \n    { \n        \"payload\": \"on\", \n        \"timeout\": global.get('setWaitTime'),\n        \"warning\": 0\n    };\n};\nreturn msg1;\n    \n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1048,
        "y": 1012,
                "a2b3e6a3.ab355",
                "6cda23b8.ef1eec"
        "id": "2142d13bd7ca8396",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "payload",
        "statusType": "auto",
        "x": 1010,
        "y": 1160,
        "id": "18d8ccc6a9b681ae",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "setWaitTime",
                "pt": "global",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 580,
        "y": 1060,
                "2142d13bd7ca8396"
        "id": "962c32d6.8a7118",
        "type": "ui_group",
        "name": "Input",
        "tab": "5bd8407f.49a06",
        "order": 5,
        "disp": true,
        "width": "6",
        "collapse": false
        "id": "74b09387.ec36dc",
        "type": "ui_group",
        "name": "Fan Status",
        "order": 2,
        "disp": true,
        "width": "6",
        "collapse": false
        "id": "864c9ec1.9c208",
        "type": "mqtt-broker",
        "broker": "192.168.1.45",
        "port": "1883",
        "clientid": "",
        "autoConnect": true,
        "usetls": false,
        "compatmode": false,
        "protocolVersion": "4",
        "keepalive": "15",
        "cleansession": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthRetain": "false",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeRetain": "false",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willRetain": "false",
        "willPayload": "",
        "willMsg": {},
        "sessionExpiry": ""
        "id": "326cc72f.e0ba98",
        "type": "ui_group",
        "name": "Input",
        "tab": "fefb308c.3ddd1",
        "order": 4,
        "disp": true,
        "width": "6",
        "collapse": false
        "id": "5bd8407f.49a06",
        "type": "ui_tab",
        "name": "Home",
        "icon": "dashboard",
        "order": 1,
        "disabled": false,
        "hidden": false
        "id": "fefb308c.3ddd1",
        "type": "ui_tab",
        "name": "Detail",
        "disabled": false,
        "hidden": false
