So not the sharpest programmer in the world... in fact not programmer. However I do like to make things, and have programmed some stuff before.
However, I am struggling with getting some logic right. I want to:
Make a system that, based on indoor/outdoor humidity, starts a ventilator.
I have so far made an bool variable that reads humidity data from my Netatmo weather station devices and toggles the the on/off variable. However, I'd like two more inputs to enter the script:
A) a dashboard controlled max time that the ventilator can run, regardless of whether it started due to humidity readings or by (B) a manual toggle.
B) a manual on/off toggle.
I have done it previously on an old Arduino with a super crappy code that I can hardly live with. Now I'm redoing it and I thought that maybe you peeps on the internet could find a minute to provide a few hints as to how that is best done...
My flow WIP: (note that I had to remove usr/pw info)
[{"id":"5dd2ed34.6894bc","type":"tab","label":"Flow 3","disabled":false,"info":""},{"id":"83eb50e3.700aa","type":"inject","z":"5dd2ed34.6894bc","name":"","topic":"5 Minutes Timer","payload":"true","payloadType":"bool","repeat":"300","crontab":"","once":true,"onceDelay":"0.1","x":580,"y":280,"wires":[["5550ac86.74f474"]]},{"id":"5550ac86.74f474","type":"netatmo-dashboard","z":"5dd2ed34.6894bc","creds":"25b2494d.73122e","x":580,"y":340,"wires":[["d9d6c6cc.b17648"]]},{"id":"9ba10667.b50b8","type":"ui_gauge","z":"5dd2ed34.6894bc","name":"","group":"1a5ecff2.92b44","order":1,"width":"3","height":"2","gtype":"gage","title":"T Kælder","label":"°C","format":"{{value}}","min":"0","max":"40","colors":["#0432ff","#00fdff","#ff2600"],"seg1":"5","seg2":"15","x":820,"y":340,"wires":[]},{"id":"7563139b.e691cc","type":"ui_gauge","z":"5dd2ed34.6894bc","name":"","group":"b37cbe7b.05118","order":1,"width":"3","height":"2","gtype":"gage","title":"T Ude","label":"°C","format":"{{value}}","min":"0","max":"40","colors":["#0432ff","#00fdff","#ff2600"],"seg1":"5","seg2":"15","x":810,"y":460,"wires":[]},{"id":"635b2b58.8aec84","type":"ui_gauge","z":"5dd2ed34.6894bc","name":"","group":"b37cbe7b.05118","order":2,"width":"3","height":"2","gtype":"gage","title":"Luftfugtighed Ude","label":"%","format":"{{value}}","min":0,"max":"100","colors":["#00fa00","#fffc00","#ff2600"],"seg1":"50","seg2":"60","x":850,"y":500,"wires":[]},{"id":"d9d6c6cc.b17648","type":"function","z":"5dd2ed34.6894bc","name":"get Netatmo Data","func":"\n\nvar msg1 = {};\nvar msg2 = {};\nvar msg3 = {};\nvar msg4 = {};\nvar msg_AhK = {};\nvar msg_AhU = {};\n\n\nmsg1.payload = Number(msg.payload.compact.modules[0].temperature); //kælder\nmsg1.topic = 'Kælder';\nmsg2.payload = Number(msg.payload.compact.modules[0].Humidity); //Kælder\nmsg2.topic = 'Kælder';\nmsg3.payload = Number(msg.payload.compact.outdoor.temperature);\nmsg3.topic = 'Ude';\nmsg4.payload = Number(msg.payload.compact.outdoor.humidity);\nmsg4.topic = 'Ude';\n//msg_AhK.payload = (6.112 * 2.718281828459^((17.67 * msg1.payload)/(msg1.payload+243.5)) * msg2.payload * 2.1674)/(273.15+msg1.payload);\n//msg_AhK.payload = (6.112*(2.718281828459^((17.67 * msg1.payload)/(msg1.payload+243.5))) * msg2.payload * 2.1674)/(273.15+msg1.payload);\n\nmsg_AhK.payload = Number(6.112* Math.pow(2.718281828459,((17.67 * msg1.payload)/(msg1.payload+243.5))) * msg2.payload * 2.1674)/(273.15+msg1.payload);\nmsg_AhK.topic = 'Kælder';\nmsg_AhU.payload = Number(6.112* Math.pow(2.718281828459,((17.67 * msg3.payload)/(msg3.payload+243.5))) * msg4.payload * 2.1674)/(273.15+msg3.payload);\nmsg_AhU.topic = 'Ude';\n\nflow.set(\"AhK\", msg_AhK);\nflow.set(\"AhU\", msg_AhU);\n\nreturn [msg1,msg2,msg_AhK,msg3,msg4,msg_AhU];","outputs":6,"noerr":0,"x":590,"y":420,"wires":[["9ba10667.b50b8"],["735f73a6.cb5c84","f5869f70.a4834"],["892c221.fca67e","eca7aaa7.d4c7e8"],["7563139b.e691cc"],["635b2b58.8aec84","d7586f4.5a02e1"],["7653673f.39f42","eca7aaa7.d4c7e8"]]},{"id":"735f73a6.cb5c84","type":"ui_gauge","z":"5dd2ed34.6894bc","name":"","group":"1a5ecff2.92b44","order":2,"width":"3","height":"2","gtype":"gage","title":"Luftfugtighed Kælder","label":"%","format":"{{value}}","min":0,"max":"100","colors":["#00fa00","#fffc00","#ff2600"],"seg1":"50","seg2":"60","x":860,"y":380,"wires":[]},{"id":"892c221.fca67e","type":"ui_gauge","z":"5dd2ed34.6894bc","name":"","group":"1a5ecff2.92b44","order":3,"width":"0","height":"0","gtype":"compass","title":"Vandindhold Kælder (g/m3)","label":"g/m3","format":"{{value | number:1}}","min":0,"max":"25","colors":["#00b500","#e6e600","#ca3838"],"seg1":"8","seg2":"12","x":880,"y":420,"wires":[]},{"id":"7653673f.39f42","type":"ui_gauge","z":"5dd2ed34.6894bc","name":"","group":"b37cbe7b.05118","order":3,"width":"0","height":"0","gtype":"compass","title":"Vandindhold Ude (g/m3)","label":"g/m3","format":"{{value | number:1}}","min":0,"max":"25","colors":["#00b500","#e6e600","#ca3838"],"seg1":"8","seg2":"12","x":870,"y":540,"wires":[]},{"id":"f361a804.0ea4d","type":"function","z":"5dd2ed34.6894bc","name":"","func":"\nvar msg1 = {};\nvar msg2 = {};\nvar msg3 = {};\nvar msg4 = {};\nvar msg5 = {};\nvar msg6 = {};\nvar msg7 = {};\nmsg7.topic = 'On/Off'\n\nvar AhK = flow.get(\"AhK\");\nvar AhU = flow.get(\"AhU\");\nvar ahTol = flow.get(\"ahTol\");\n\nmsg1.payload = AhK.payload;\nmsg2.payload = AhU.payload;\nmsg4.payload = ahTol.payload;\nmsg5.payload = AhU.payload*(1+(ahTol.payload/100));\nmsg6.payload = AhU.payload-AhK.payload;\n\nif (AhK.payload > (msg5.payload) ) {\nmsg3.payload = true;\nhumOnoff = true;\nmsg7.payload = 20;\n}\nelse {\nmsg3.payload = false;\nhumOnoff =false;\nmsg7.payload = 0;\n\n}\n\n\n\nreturn [msg1, msg2, msg3, msg4, msg5, msg6, msg7];","outputs":7,"noerr":0,"x":502,"y":825,"wires":[["967df6b6.66d01"],["f95cc6b1.beeed"],["9f2359bf.354838"],["4c9de6d7.98bc9"],["d7cbd3ee.50a16"],["4b6580c1.f10c6","8343ee88.6811a"],["c576495c.2a52d8","eca7aaa7.d4c7e8"]]},{"id":"d4f21e42.19fb9","type":"inject","z":"5dd2ed34.6894bc","name":"","topic":"","payload":"true","payloadType":"bool","repeat":"1","crontab":"","once":true,"onceDelay":"0.2","x":362,"y":825,"wires":[["f361a804.0ea4d"]]},{"id":"9f2359bf.354838","type":"ui_text","z":"5dd2ed34.6894bc","group":"44e5433c.f98cac","order":5,"width":0,"height":0,"name":"","label":"Ventilator Status: ","format":"{{msg.payload}}","layout":"row-right","x":742,"y":805,"wires":[]},{"id":"ecbb9f58.459318","type":"ui_slider","z":"5dd2ed34.6894bc","name":"","label":"ahTol slider","tooltip":"{{value}} %","group":"8eae17cc.67f588","order":1,"width":0,"height":0,"passthru":false,"outs":"all","topic":"","min":"5","max":"50","step":"5","x":240,"y":540,"wires":[["aaf9ce50.654c9"]]},{"id":"aaf9ce50.654c9","type":"function","z":"5dd2ed34.6894bc","name":"ahTol","func":"var ahTol = {};\n\n\nahTol.payload = msg.payload;\n\nflow.set(\"ahTol\", ahTol);\n\nreturn msg;","outputs":1,"noerr":0,"x":390,"y":540,"wires":[[]]},{"id":"967df6b6.66d01","type":"ui_text","z":"5dd2ed34.6894bc","group":"44e5433c.f98cac","order":2,"width":0,"height":0,"name":"","label":"Vandindhold Kælder (g/m3)","format":"{{msg.payload | number:1}}","layout":"row-spread","x":772,"y":725,"wires":[]},{"id":"f95cc6b1.beeed","type":"ui_text","z":"5dd2ed34.6894bc","group":"44e5433c.f98cac","order":4,"width":0,"height":0,"name":"","label":"Vandindhold Ude (g/m3)","format":"{{msg.payload | number:1}}","layout":"row-spread","x":762,"y":765,"wires":[]},{"id":"4b6580c1.f10c6","type":"ui_gauge","z":"5dd2ed34.6894bc","name":"","group":"44e5433c.f98cac","order":1,"width":"3","height":"3","gtype":"compass","title":"aH diff. (Ude-Kæl)","label":"g/m3","format":"{{value | number:1}}","min":"-10","max":"10","colors":["#00b500","#e6e600","#ca3838"],"seg1":"65","seg2":"70","x":742,"y":925,"wires":[]},{"id":"d7cbd3ee.50a16","type":"ui_text","z":"5dd2ed34.6894bc","group":"8eae17cc.67f588","order":3,"width":"3","height":"3","name":"","label":"Setpoint","format":"{{msg.payload | number:1}}","layout":"col-center","x":712,"y":885,"wires":[],"info":"__"},{"id":"8343ee88.6811a","type":"ui_chart","z":"5dd2ed34.6894bc","name":"","group":"44e5433c.f98cac","order":3,"width":"3","height":"3","label":"Forskel","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"bezier","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"5","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":932,"y":925,"wires":[[]]},{"id":"784a5652.4b54a8","type":"inject","z":"5dd2ed34.6894bc","name":"","topic":"","payload":"","payloadType":"date","repeat":"1","crontab":"","once":true,"onceDelay":0.1,"x":230,"y":1020,"wires":[["2f51fa3f.e3658e","ee10749f.6f4c78"]]},{"id":"279da797.013538","type":"ui_text_input","z":"5dd2ed34.6894bc","name":"","label":"Dato","tooltip":"","group":"5bd990b3.dca3","order":1,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"","x":610,"y":1000,"wires":[[]]},{"id":"2f51fa3f.e3658e","type":"moment","z":"5dd2ed34.6894bc","name":"","topic":"","input":"","inputType":"msg","inTz":"Europe/Copenhagen","adjAmount":0,"adjType":"days","adjDir":"add","format":"DD/MM/Y","locale":"en_gb","output":"","outputType":"msg","outTz":"Europe/Copenhagen","x":440,"y":1000,"wires":[["279da797.013538"]]},{"id":"647de97b.5d0b7","type":"ui_text_input","z":"5dd2ed34.6894bc","name":"","label":"Tid","tooltip":"","group":"5bd990b3.dca3","order":2,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"","x":610,"y":1040,"wires":[[]]},{"id":"ee10749f.6f4c78","type":"moment","z":"5dd2ed34.6894bc","name":"","topic":"","input":"","inputType":"msg","inTz":"Europe/Copenhagen","adjAmount":0,"adjType":"days","adjDir":"add","format":"HH:mm:ss","locale":"en_gb","output":"","outputType":"msg","outTz":"Europe/Copenhagen","x":440,"y":1040,"wires":[["647de97b.5d0b7"]]},{"id":"4c9de6d7.98bc9","type":"ui_gauge","z":"5dd2ed34.6894bc","name":"","group":"8eae17cc.67f588","order":2,"width":"3","height":"3","gtype":"gage","title":"aH Tol","label":"%","format":"{{value | number:1}}","min":"0","max":"100","colors":["#53d6fd","#00a3d8","#006d8f"],"seg1":"65","seg2":"70","x":702,"y":845,"wires":[]},{"id":"eca7aaa7.d4c7e8","type":"ui_chart","z":"5dd2ed34.6894bc","name":"","group":"44e5433c.f98cac","order":6,"width":"6","height":"4","label":"Vandindhold (g/m3)","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"bezier","nodata":"","dot":false,"ymin":"0","ymax":"20","removeOlder":"5","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#ff2600","#3a88fe","#00fa00","#ff2600","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":1110,"y":480,"wires":[[]]},{"id":"c576495c.2a52d8","type":"ui_chart","z":"5dd2ed34.6894bc","name":"","group":"8eae17cc.67f588","order":4,"width":"6","height":"2","label":"On/Off","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"step","nodata":"","dot":false,"ymin":"0","ymax":"20","removeOlder":"5","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#ff2600","#ff2600","#ff2600","#ff2600","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":1002,"y":805,"wires":[[]]},{"id":"f5869f70.a4834","type":"ui_chart","z":"5dd2ed34.6894bc","name":"","group":"1a5ecff2.92b44","order":3,"width":0,"height":0,"label":"Luftfugtighed Kælder","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"20","ymax":"100","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":1120,"y":400,"wires":[[]]},{"id":"d7586f4.5a02e1","type":"ui_chart","z":"5dd2ed34.6894bc","name":"","group":"b37cbe7b.05118","order":3,"width":0,"height":0,"label":"Luftfugtighed Ude","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"20","ymax":"100","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":1110,"y":440,"wires":[[]]},{"id":"b0c09932.02228","type":"inject","z":"5dd2ed34.6894bc","name":"","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":true,"onceDelay":0.1,"x":90,"y":540,"wires":[["ecbb9f58.459318"]]},{"id":"25b2494d.73122e","type":"netatmo-config-node","z":"","client_id”:”HIDDEN”,”client_secret”:”HIDDEN”,”username”:”HIDDEN”,”password”:”HIDDEN”},{“id":"1a5ecff2.92b44","type":"ui_group","z":"","name":"Kælder","tab":"c097c657.697cb8","order":2,"disp":true,"width":"6","collapse":false},{"id":"b37cbe7b.05118","type":"ui_group","z":"","name":"Ude","tab":"c097c657.697cb8","order":1,"disp":true,"width":"6","collapse":false},{"id":"44e5433c.f98cac","type":"ui_group","z":"","name":"Analyse","tab":"c097c657.697cb8","order":3,"disp":true,"width":"6","collapse":false},{"id":"8eae17cc.67f588","type":"ui_group","z":"","name":"Input","tab":"c097c657.697cb8","order":4,"disp":true,"width":"6","collapse":false},{"id":"5bd990b3.dca3","type":"ui_group","z":"","name":"Info","tab":"c097c657.697cb8","order":5,"disp":true,"width":"6","collapse":false},{"id":"c097c657.697cb8","type":"ui_tab","z":"","name":"Main","icon":"dashboard","disabled":false,"hidden":false}]
