How to use context in custom node
so i create new node
and need to sotre some data in context node
https://nodered.org/docs/creating-nodes/context
my node
module.exports = function(RED) {
    function ClientNode(config) {
        RED.nodes.createNode(this,config);
        var node = this;
        context.set("myData",1);
        node.on('input', function(msg) {
            msg.payload = this.context.get("myData");
            // msg.payload = msg.payload.toLowerCase();
            node.send(msg);
        setTimeout(function () {
           // this.context().flow.set("test", 1)
            var msg =   context.get("myData");
            node.send(msg);
        }, 3000);
    RED.nodes.registerType("Client",ClientNode);
    RED.httpAdmin.post("/client/:id", RED.auth.needsPermission("client.write"), function(req,res) {
        var node = RED.nodes.getNode(req.params.id);
        if (node != null) {
            try {
                msg = {payload:"", topic:""}
                msg.payload = node.name;
                msg.topic = node.id
                msg.z = node.z
                node.send(msg);
                res.sendStatus(200);
            } catch(err) {
                res.sendStatus(500);
                node.error("Restore failed: "+ err.toString());
        } else {
            res.sendStatus(404);
but I cant
am try with :
this.context().set("data", 1);
this.context.set("data", 1);
but all not work
error in console log
10 Nov 08:54:34 - [error] [Client:728bd51e7616989f] ReferenceError: context is not defined
or
10 Nov 08:53:16 - [error] [Client:728bd51e7616989f] TypeError: this.context.set is not a function
I've not used context in a custom node but have you tried something like:
const nodeContext = this.context()
nodeContext.set('data', 1)
yes I solved ths thx
If you wanted a single line rather than an intermediate variable, you might try:
(this.context()).set('data', 1)
Not tried that but I think it would work (note the extra brackets).
