How to use GitHub Co-pilot into Node-Red?
Hi, These days i am practicing Github Co-Pilot and i want to use this into Node-Red. If it is possible to use, please guide me.
Thanks.
Hi @ranjeetCode - it's not available out of the box with Node-RED. A couple of options I'm aware of:
  • If you run node-RED through FlowFuse Cloud, then you have access to the FlowFuse Assistant, which is a Co-Pilot type interface for function nodes, json input, etc.
  • The Node-RED Function GPT node can also be installed, and connected to your own Co-Pilot account on any Node-RED instance
Thanks for your reply.
