Hey, I am a beginner in Node-Red and I have created the Temperature Monitoring Application using ESP8266 and SHT31 I2C sensor module connected via MQTT server to Node red dashboard in Windows Operating System.
But Now I want to use this on my smartphone whenever I am trying to make it work with the Termux using tutorial
but at while installing the node red, I ended up with the error
npm i -g --unsafe-perm node-red
npm ERR! Cannot read property 'length' of undefined
npm ERR! /data/data/com.termux/files/home/.npm/_logs/2019-01-23T06_01_42_814Z-debug.log
I have also checked out the earlier post about this problem but it din't worked out.
Can anyone suggest how can I change the settings manually in termux by switching to the directory they have mentioned in the post?
Can I first check that you really want to run node-red on the phone and not just be able to view, on the phone, the dashboard of the node-red from the node-red running on windows.
Hi, I want to run node red so that I can create application work with in my smartphone. Nothing is related to the application I have created in windows
