How to use push button to toggle Led in raspberry pi?
Hello my name is Jason,
I have a question about how to set a push button as on/off function.
I already started to construct a push button which functions quite nicely as long as I push and release the button. It then changes from 1 to 0. But my intention that I very much would like to do is to turn on and off the LED light by PRESSING the button instead of releasing.
Kind regards,
Jason
Is it a physical button connected to a GPIO or a Node-RED dashboard button?
Can you paste a picture of your flow?
Near as I can tell, Node-Red's ui_button only "triggers" on release - as I discovered when working on this topic...
However there are some solutions - such as creating your own button ...
Hi Jason,
Have a look at the node-red-contrib-toggle
It will do the job.
Dear Cymplecy
Yes it is a physical button connected to a GPIO of a raspberry pi( Ground -> GPIO 26) and a LED to the pins ( ground -> GIO 16)
When i push the button the state from the button change to 0 en the led turns off and when i release the button the state change back to 1
( when I press the push button )
( when I release the push button )
I would like that the LED stay on when the push button is released and goes back out when I press again
Try this:
screenshot-192.168.0.118_1880-2021.09.24-13_35_07
and then make sure that the topic of this:
screenshot-discourse.nodered.org-2021.09.24-13_36_35
is set to: toggle
Ed
I tried but then the led doesn't work anymore it just stays on
Settings Input
Toggle node
Add this before the Toggle node:
screenshot-192.168.0.118_1880-2021.09.24-14_52_00
Edit it to look like this:
Ed
Thx !!!
this did the job
Or a basic change node :slight_smile:
No need for any JS :slight_smile:
