How to use shared code?
  • new to node-red ( and here )
there are many posts sharing code
also a general info how to do that:
https://discourse.nodered.org/t/how-to-share-code-or-flow-json/506
ahm,
but i need info how to use such a code snippet
in the node-red editor?
without that a screen-print of a node open in editor helps me more
for understanding or creating that manually.
? fast sharing work flow ?
Copy the code.
Then in flow editor press ctrl I or use menu and select import.
Paste the code in the box and press import.
In the flow editor you should see a new flow.
https://nodered.org/docs/user-guide/editor/workspace/import-export
that was fast... thank you, will try
