How to use the response TCP in the TCP node in node-red
How to use the response TCP in the TCP node in node-red and under what circumstances
Please give more detail about your issue.
What data do you see and what is the problem?
It is TCP node as a client, input server IP, click on the connection to communicate with the server, TCP node client set to respond to TCP can also communicate, want to know the difference between the two settings
