So in my fun MQTT project I thought - lets try seeing if I can set it up to use websockets (just on LAN)
So, I created this little flow
[{"id":"99a9e9a5e664458a","type":"websocket out","z":"f7546f055375d300","name":"","server":"5ffaa82e38835477","client":"","x":1150,"y":600,"wires":[]},{"id":"c9a58f87db1d1413","type":"change","z":"f7546f055375d300","name":"set CONNACK","rules":[{"t":"set","p":"payload","pt":"msg","to":"[\"0b00100000\",2,0,0]","tot":"bin"}],"action":"","property":"","from":"","to":"","reg":false,"x":800,"y":560,"wires":[["f9ae1ff880e022d1","99a9e9a5e664458a"]]},{"id":"3f40582d7a5603c2","type":"switch","z":"f7546f055375d300","name":"Test packet type","property":"payload.0","propertyType":"msg","rules":[{"t":"eq","v":"16","vt":"num"},{"t":"eq","v":"0xC0","vt":"num"},{"t":"gte","v":"0b00110000","vt":"num"},{"t":"eq","v":"0x82","vt":"num"},{"t":"eq","v":"0b10100010","vt":"num"},{"t":"eq","v":"0b11100000","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":7,"x":675,"y":580,"wires":[["c9a58f87db1d1413"],[],[],[],[],[],[]],"l":false},{"id":"f9ae1ff880e022d1","type":"debug","z":"f7546f055375d300","name":"Test","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"msg","x":970,"y":640,"wires":[]},{"id":"2251a27865d0e996","type":"join","z":"f7546f055375d300","name":"","mode":"custom","build":"buffer","property":"payload","propertyType":"msg","key":"topic","joiner":"","joinerType":"bin","accumulate":false,"timeout":"1","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":590,"y":600,"wires":[["3f40582d7a5603c2","4ac41d3fa7382b13"]]},{"id":"4ac41d3fa7382b13","type":"junction","z":"f7546f055375d300","x":660,"y":640,"wires":[["f9ae1ff880e022d1"]]},{"id":"76eb165d46f3715b","type":"websocket in","z":"f7546f055375d300","name":"","server":"5ffaa82e38835477","client":"","x":440,"y":600,"wires":[["2251a27865d0e996"]]},{"id":"5ffaa82e38835477","type":"websocket-listener","path":"/ws/example","wholemsg":"true"}]
And it receives a connection message (but in two parts - hence need for join) and using my same switch that I used for TCP connections - I check the packet and then send an acknowledgement
But my client doesn't actually connect so I wondering if I've setup the websocket out node properly
The TCP out node has a reply mode but the websocket one seems to lack this
[edit] note - it may be an issue with my client but I just need to know whether I#ve setup NR correctly
