Hello, I am building a flow with websocket connections using my project Webhook Relay (https://webhookrelay.com/v1/guide/socket-server - it allows receiving webhook without having public IP or configuring NAT/firewall) and it's mostly seem to be working, but it took me a while to figure out that even the websocket nodes are showing "disconnected", they are actually connected and working:
Is it a known bug or am I doing something wrong with my configuration?
I will try creating standalone websocket module as well, as creating a flow manually seems quite a long ceremony
Whole flow:
"id": "febecf29.9c98f",
"type": "tab",
"label": "webhook process",
"disabled": false,
"info": ""
"id": "2929f07a.1283",
"type": "websocket out",
"z": "febecf29.9c98f",
"name": "[ws] wss://my.webhookrelay.com/v1/socket",
"server": "",
"client": "667a3498.112ddc",
"x": 910,
"y": 120,
"id": "62a9f4b6.acdabc",
"type": "inject",
"name": "initial ws auth request",
"topic": "",
"payload": "{\"action\":\"auth\",\"key\":\"[TOKEN KEY]\",\"secret\":\"[TOKEN SECRET]\"}",
"payloadType": "json",
"repeat": "",
"crontab": "",
"once": true,
"onceDelay": "0.5",
"x": 160,
"y": 120,
"2929f07a.1283"
"id": "8848a243.ba36f",
"type": "websocket in",
"server": "",
"x": 200,
"y": 280,
"4ef219e5.6f1908"
"id": "26fabc07.34a754",
"type": "function",
"name": "subscribe to bucket",
"func": "let payload = {action:\"subscribe\",buckets:[\"nodered\"]}\nreturn {payload: JSON.stringify(payload)};",
"outputs": 1,
"noerr": 0,
"x": 590,
"y": 180,
"2929f07a.1283"
"id": "4ef219e5.6f1908",
"type": "json",
"property": "payload",
"action": "",
"pretty": false,
"x": 450,
"y": 280,
"bfe57ee5.7a532"
"id": "2a508cdf.748334",
"type": "switch",
"name": "auth switch",
"property": "payload.status",
"propertyType": "msg",
"rules": [
"t": "eq",
"v": "authenticated",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 790,
"y": 240,
"26fabc07.34a754",
"5ad59a16.0ecf04"
"id": "bfe57ee5.7a532",
"type": "switch",
"name": "type switch",
"property": "payload.type",
"rules": [
"t": "eq",
"v": "status",
"vt": "str"
"t": "eq",
"v": "webhook",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 610,
"y": 280,
"2a508cdf.748334"
"108e396f.08c397"
"id": "108e396f.08c397",
"type": "debug",
"name": "process webhook",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"x": 850,
"y": 340,
"id": "5ad59a16.0ecf04",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"x": 990,
"y": 280,
"id": "667a3498.112ddc",
"type": "websocket-client",
"z": "",
"path": "wss://my.webhookrelay.com/v1/socket",
"tls": "",
"wholemsg": "false"
