Does anyone know why does my websocket disconnect everytime i inject a message.
Yes, I see it clearly
How can anyone know what is wrong unless you give a lot more information?
I have a server that im trying to reach out to with websocket node.I have a inject node that is going in websocket out(connect to), and websocket in node that ins connected with debug node.
Under the websocket node i get text that says connected
And everytime i try to inject the msg it disconnects
Select those four nodes and Export to Clipboard. (Ctrl+E or via menus). Then paste the flow here using the technique described in this post - How to share code or flow json.
Then we will be able to see how you have configured them.
[{"id":"5fe717c8.e30b68","type":"debug","z":"2bf64bee.803cc4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1250,"y":1700,"wires":},{"id":"93379af6.20fb58","type":"websocket in","z":"2bf64bee.803cc4","name":"","server":"1c783539.8cbcfb","client":"","x":850,"y":1700,"wires":[["5fe717c8.e30b68"]]},{"id":"159fbed5.3e5f41","type":"websocket out","z":"2bf64bee.803cc4","name":"","server":"","client":"2b3d73a0.959a3c","x":1140,"y":1520,"wires":},{"id":"c5a516af.6c1558","type":"inject","z":"2bf64bee.803cc4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"SUBSCRIBE com.alephone.modbus.datapoint#ZHT0062_1.System.LeadPump.Selection WebEvent/1.0 ","payloadType":"str","x":730,"y":1520,"wires":[["159fbed5.3e5f41"]]},{"id":"1c783539.8cbcfb","type":"websocket-listener","path":"ws://192.168.1.41:22080/webevent","wholemsg":"false"},{"id":"2b3d73a0.959a3c","type":"websocket-client","path":"ws://192.168.1.41:22080/webevent/","tls":"","wholemsg":"false"}]
You have not followed the instructions in the link I posted.
"id": "cbd0cecb.dacfd",
"type": "debug",
"z": "2feacd9b.ac6522",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"statusType": "auto",
"x": 770,
"y": 780,
"id": "8ae8f2e4.22942",
"type": "websocket in",
"server": "fb40ab8c.2074c8",
"client": "",
"x": 290,
"y": 780,
"cbd0cecb.dacfd"
"id": "9f6c89bd.09bdc8",
"type": "websocket out",
"server": "",
"client": "416da4de.9734dc",
"x": 780,
"y": 640,
"id": "14c70c0e.6a9264",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "{\"name\":\"ZHT0062_1.System.LeadPump.Selection\"}",
"payloadType": "json",
"x": 290,
"y": 640,
"9f6c89bd.09bdc8"
"id": "fb40ab8c.2074c8",
"type": "websocket-listener",
"path": "ws://192.168.1.41:22080/webevent",
"wholemsg": "false"
"id": "416da4de.9734dc",
"type": "websocket-client",
"tls": "",
"wholemsg": "false"
What OS/hardware are you running node red on?
What version of node-red?
What version of node.js?
What does the server log show when it disconnects?
win10
node.js v15.2.1
node-red v1.2.9
it shows nothing..
That is not a recommended version of node.js. It may not be the cause of the problem but I suggest that you go back to 14.x in order to check.
After downgrading you will need to re-install node-red and go into your .node-red folder and run
npm install rebuild
If that doesn't help then can you increase the log level on the server?
