I have two NR instance running in docker on port 9883 and port 9884.
On the first one (9883) I add a Websocket out node, to connect to the other instance, as below:
On the second (9884) I add a Websocket in node, as below:
Whatever I do to the Websocket in node, such as:
- Disable the node
- Delete the node
The Websocket Out still shows as connected. In fact, no error or anything is thrown in debug or even the status node. This is a big problem, because I cannot detect Websocket issues!
The only time I can get the Websocket out node to show disconnected is if I actually take down the NR instance it's connected to!
I just also noticed that if I change the Websocket In path, so that the Websocket out is pointing to a WS path that no longer exists, it correctly shows disconnected?!
