How to zip multiple files
I want to compress multiple files into one zip file:
When reading the instructions of zip node, it seems to be able to do this with the input payload is Array, I tried it without understanding how input filename and payload are correct !?
[{"id":"db2e6476.273128","type":"file in","z":"aa5a77d3.21b528","name":"","filename":"","format":"","chunk":false,"sendError":false,"encoding":"none","x":1210,"y":2400,"wires":[["29eaaf6.381265"]]},{"id":"9cb5f8ae.f87fb8","type":"function","z":"aa5a77d3.21b528","name":"","func":"var arrFiles = [];\n\narrFiles.push('C:\\\\Temp\\\\Test\\\\File1.txt');\narrFiles.push('C:\\\\Temp\\\\Test\\\\File2.txt');\narrFiles.push('C:\\\\Temp\\\\Test\\\\File3.txt');\n\n//msg.filename = arrFiles.toString();\nmsg.arrFiles = arrFiles;\n\nreturn msg;","outputs":1,"noerr":0,"x":870,"y":2300,"wires":[["30b15e87.412962"]]},{"id":"2ced30c0.015fa","type":"inject","z":"aa5a77d3.21b528","name":"","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":690,"y":2300,"wires":[["9cb5f8ae.f87fb8"]]},{"id":"d2f256d9.3a7c78","type":"split","z":"aa5a77d3.21b528","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":870,"y":2400,"wires":[["22656107.c3054e"]]},{"id":"22656107.c3054e","type":"change","z":"aa5a77d3.21b528","name":"","rules":[{"t":"set","p":"filename","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1030,"y":2400,"wires":[["db2e6476.273128"]]},{"id":"30b15e87.412962","type":"change","z":"aa5a77d3.21b528","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"arrFiles","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":700,"y":2400,"wires":[["d2f256d9.3a7c78"]]},{"id":"e464d114.b7505","type":"zip","z":"aa5a77d3.21b528","name":"","mode":"compress","filename":"","outasstring":false,"x":830,"y":2500,"wires":[["2d2f0be2.c417b4"]]},{"id":"2d2f0be2.c417b4","type":"change","z":"aa5a77d3.21b528","name":"","rules":[{"t":"set","p":"filenameNew","pt":"msg","to":"$replace(filename,/^.*[\\\\\\/]/, '')\t","tot":"jsonata"},{"t":"change","p":"filename","pt":"msg","from":"filenameNew","fromt":"msg","to":"ZIP_NEW.zip","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1183.234375,"y":2495.25,"wires":[["de7cf02e.901ff"]]},{"id":"de7cf02e.901ff","type":"change","z":"aa5a77d3.21b528","name":"","rules":[{"t":"set","p":"filename","pt":"msg","to":"\"C:\\\\Temp\\\\Test\\\\\" & msg.filename","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1390,"y":2500,"wires":[["69ffe535.eecedc"]]},{"id":"69ffe535.eecedc","type":"file","z":"aa5a77d3.21b528","name":"","filename":"","appendNewline":true,"createDir":true,"overwriteFile":"false","encoding":"none","x":1130,"y":2600,"wires":[["8192bbdf.6cf858"]]},{"id":"29eaaf6.381265","type":"change","z":"aa5a77d3.21b528","name":"","rules":[{"t":"change","p":"filename","pt":"msg","from":"C:\\Temp\\Test\\","fromt":"str","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1380,"y":2400,"wires":[["e464d114.b7505"]]},{"id":"8192bbdf.6cf858","type":"debug","z":"aa5a77d3.21b528","name":"msg","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1430,"y":2600,"wires":[]},{"id":"23f55ef0.5ed142","type":"join","z":"aa5a77d3.21b528","name":"","mode":"auto","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":670,"y":2500,"wires":[["e464d114.b7505"]]},{"id":"26b89ffb.7ba54","type":"join","z":"aa5a77d3.21b528","name":"","mode":"auto","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":993.234375,"y":2535.25,"wires":[["2d2f0be2.c417b4"]]},{"id":"c11dbe74.ba0d8","type":"join","z":"aa5a77d3.21b528","name":"","mode":"auto","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1270,"y":2640,"wires":[[]]}]
Please tell me.
Thanks!
No, it is not.
After you load each file you need to put its data into an object with the new zipped filename
e.g.
function node...
var filename_only = msg.filename.split("/").pop(); // << I am guessing file name is in msg.filename
var o = {
  payload: msg.payload, //store file data in object.payload
  filename: filename_only
msg.payload = o;
Then feed that into a JOIN node set to create an array.
The final payload going into the ZIP must be an array of objects, with each object having filename and payload - like this...
    payload: [buffer,of,file,data],
    filename: "filename.txt"
    payload: [another,buffer,of,file,data],
    filename: "a_different_filename.txt"
Done!
@Steve-Mcl Thank you for your enthusiastic guidance!
