Html in Notification Pop-Up
hi I use Notification Pop-Up
it is possible to show html content in a popup dialog
or if any other node for send html to popup like messageBox in jquery
thx
I wonder what this option does...
thx
am sorry
I did not pay attention
:slight_smile: In the OP's defence, it is slightly confusing.
It should probably read 'Accept raw HTML/JavaScript in msg.payload to format popup.'
Unless of course the user is allowed to type and send HTML code in the input field that pop's up. In which case I have said nothing. :slight_smile:
good shout - will clarify as you suggest.
Note: the reason this is optional is of course that it is indeed a way to do code injection so you need to ensure you have sanitised any html/js you send to the notification - and don't allow any previous user input to leak through.
