Hello together,
for the first, excuse me for my bad english.
for the second, I doesn't know much about programming.
what i want to do is:
html to activate a GPIO for maybe 15 minutes
so when I write "http://192.168.X.X/test/GPIO2" in my browser, i want to activate the GPIO2
when I write "http://192.168.X.X/test/GPIO3" in my browser, i want to activate the GPIO3
I hope you can help me.
And again, excuse me for my bad english, I am german.
Okay but i don`t know, how i can do it.
When i write "http://192.168.178.35/test?test=GPIO" i receive it.
But how can i go on with this information?
i mean my GPIO needs a 0 or >1 to switch.
and in the funktion how can i say when GPIO1 then Out1 and when GPIO2 then Out2
Take a look at the switch node and the change node
Try using the switch node and get the data from msg.req.test. Send the payload do desired output
how can i send it to the payload?
on a function node
var gpio = msg.req.test
msg.payload = {"gpio": gpio}
i tryed it but it doesn't worked.
my flow is like this:
- http node with "Method GET" an "URL /test"
- funktion node with:
"var gpio = msg.req.test;"
"msg.payload = {"gpio":gpio};"
- switch node, here i don't know what to do!!!
- GPIO node
my URL is "http://192.168.178.35/test?test=gpio"
can you say me what i have to do?
what im looking for ist to switch on GPIO2 when the URL ist test=GPIO2, an to switch on GPIO3 when the URL ist test=GPIO3.
Please export your flow
Then read the following post How to share code or flow json and follow the instructions to post your flow here.
