HTML5 Videostream from your IP Camera
Bevore I was only able to add JPG Images or an MJPEG Stream to the Node-RED Dashboard. But INSTAR recently published a set of Javascript files (webassembled FFMPEG) to bring their cameras h.264 video stream in line with Browser requirements.
Issues
- Audio does not work in Safari - Chrome works fine.
- The video streams keeps running until you close the browser tab. Which is a little bit annoying, as the videos do need a lot of CPU power.
I think both issues are related - the script contains a function to start and stop the video stream manually. I believe Safari (possibly also Firefox) block audio on automatically started video streams. I guess I will need to add a button to manually start and stop the video.
Setup
- What I have so far - I added an HTML Template Node for every camera:
- I added the HTML code provided by INSTAR and copied the JS files into my Node-RED static directory (you need to create a sub directory called
/ui) so I can link them into the page:
httpStatic
โโโ ui
โโโ js
โโโ commonff.js
โโโ decworker.js
โโโ g711.js
โโโ hi_h264dec.js
โโโ libffmpeg.js
โโโ libffmpeg.wasm
โโโ NetThread.js
โโโ pcm-player.js
โโโ video-player.js
โโโ webgl-player.js
One pitfall here is that the player variable and the activeVideo ID has to be unique for every camera. The following is the example of my 5th camera, which I added in Node-RED. Accordingly, the canvas has the ID activeVideo5 and the player has the name player5. For the next camera I could copy this template node, but had to change these names to activeVideo6 and player6 in ALL places!
<script type="text/javascript" src="js/commonff.js"></script>
<script type="text/javascript" src="js/video-player.js"></script>
<script type="text/javascript" src="js/webgl-player.js"></script>
<script type="text/javascript" src="js/pcm-player.js"></script>
<script type="text/javascript" src="js/g711.js"></script>
<!-- this is the video the video element -->
<canvas id="activeVideo5" width="1280" height="720"></canvas>
<script>
var cam_host = '192.168.2.20'; // DDNS or local ip
var cam_port = 80; // http port
var cam_user = 'admin'; // credentials for guest account recommended
var cam_pass = 'instar'; // credentials for guest account recommended
var cam_stream = 13; // 11 = FullHD; 12 medium res, 13 small res
var canvas = document.getElementById("activeVideo5");
var player5 = null;
function startvideo(cam_host, cam_port, cam_stream, cam_user, cam_pass){
// init video player5
player5 = new HxPlayer();
self.player5.init({canvas:canvas,width:640,height:352});
// play video
player5.playvideo(cam_host, cam_port, cam_stream, cam_user, cam_pass);
function stopvideo(){
// stop video
player5.stopvideo();
player5 = null;
// initialize and play video
</script>
Node-RED Dashboard
You can now see the h.264 video of all integrated cameras in your Node-RED Dashboard:
