Htmllint for locales html file
Hi.
I created a grunt plugin that runs htmllint for locales HTML files created by custom nodes and so on.
With this, you can easily check that the tags are not closed or that they are not used as HTML structures.
See grunt-nr-locales-htmllint for details.
Example
run grunt
check code
In fact the type "text/x-red" is historical. You can now change that to "text/html" and your normal linter should work. We are changing files to that as we need to rather than change all at once.
Thank you very much! That's very good information for me.
From now on, I will do that too.
