So I have an API that I am requesting JSON data from, and it returns an array or 60 or so site names with descriptions. I can access a single site name like so: msg.payload.data[3].name but what I need to do is the following (written in pseudo code)
for each item in array
msg.url = "http: //apiproviders url/ + msg.payload.data[3].name + "/authcode"
Then when I have the URL built, I send that on with headers to the HTTP Request node and the last step is storing the msg.payload.data[].name with the returned json data and push it into Influxdb.
Do I need to write a function that sets a variable if there is none, gets first array item, constructs the url, increments the variable, returns the msg.url and msg.headers, pipes that into a http request node and then loops back to said function to run the next entry?
Should I be writing each result into influx after the http request and before looping or wait until I build up another array?
I tried handling the data even in pure JSON form from an exec node using my script below but it would split it into two arrays. I'm getting all the data I need back now - just up to the loop part.
Here is what I have so far:
[{"id":"81865ef2.450ea","type":"json","z":"523f91ce.e2d68","name":"","property":"payload","action":"obj","pretty":false,"x":730,"y":100,"wires":[["af28558c.02a278"]]},{"id":"273bc210.ad209e","type":"debug","z":"523f91ce.e2d68","name":"JSON","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":690,"y":240,"wires":[]},{"id":"32296b12.d1ff34","type":"inject","z":"523f91ce.e2d68","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":160,"y":100,"wires":[["8e56f979.9e3248"]]},{"id":"867a1300.70abb","type":"http request","z":"523f91ce.e2d68","name":"Request Xirrus AuthKey","method":"GET","ret":"obj","url":"https://api.cloud.xirrus.com/v1/oauth/token?password=password&grant_type=password&username=username","tls":"","x":530,"y":100,"wires":[["81865ef2.450ea"]]},{"id":"8e56f979.9e3248","type":"function","z":"523f91ce.e2d68","name":"set headers","func":"msg.headers = {};\nmsg.headers['Content-type'] = 'application/json';\nmsg.headers['x-api-key'] = 'somekey';\nreturn msg;","outputs":1,"noerr":0,"x":310,"y":100,"wires":[["867a1300.70abb"]]},{"id":"f6db19de.a820f8","type":"http request","z":"523f91ce.e2d68","name":"Request Profiles","method":"GET","ret":"obj","url":"http s://api.cloud.xirrus.com/v1/rest/api/profiles.json","tls":"","x":500,"y":180,"wires":[["7780aa81.cb24d4"]]},{"id":"af28558c.02a278","type":"function","z":"523f91ce.e2d68","name":"set headers","func":"global.set(\"auth_key\",msg.payload.token_type + \" \" + msg.payload.access_token);\nmsg.headers = {};\nmsg.headers['Content-type'] = 'application/json';\nmsg.headers['x-api-key'] = 'somekey';\nmsg.headers['Authorization'] = global.get(\"auth_key\");\nreturn msg;","outputs":1,"noerr":0,"x":310,"y":180,"wires":[["f6db19de.a820f8"]]},{"id":"7780aa81.cb24d4","type":"json","z":"523f91ce.e2d68","name":"","property":"payload","action":"obj","pretty":false,"x":650,"y":180,"wires":[["bd3a5c9b.f293a"]]},{"id":"7e6e536e.54792c","type":"http request","z":"523f91ce.e2d68","name":"","method":"GET","ret":"txt","url":"","tls":"","x":490,"y":240,"wires":[["273bc210.ad209e"]]},{"id":"bd3a5c9b.f293a","type":"function","z":"523f91ce.e2d68","name":"Get 1 site APs","func":"\nmsg.url = {};\nmsg.url = \"http s://api.cloud.xirrus.com/v1/rest/api/profiles.json/\" + msg.payload.data[3].name + \"/accesspoints/statuses\";\nmsg.headers = {};\nmsg.headers['Content-type'] = 'application/json';\nmsg.headers['x-api-key'] = 'somekey';\nmsg.headers['Authorization'] = global.get(\"auth_key\");\nreturn msg;","outputs":1,"noerr":0,"x":320,"y":240,"wires":[["7e6e536e.54792c"]]}]
Here is my python script to give you an idea of how im doing it in python:
import requests
import json
header ={
"content-Type": "application/json",
"x-api-key": "somekey"
api_response = requests.get("htt ps://api.cloud.xirrus.com/v1/oauth/token?password=xirruspwd&grant_type=password&username=ourusername", headers = header)
api_set = json.dumps(api_response.json())
auth_key = (json.loads(api_set)['access_token'])
xms_url = "ht tps://api.cloud.xirrus.com/v1/rest/api/profiles.json"
header ={
"x-api-key": "somekey",
"Authorization": "bearer "+auth_key
response = requests.get(xms_url, headers = header)
#print(response.json())
profiles = json.dumps(response.json())
profile_list = []
try:
decoded = json.loads(profiles)
# Access data
for x in decoded['data']:
profile_list.append(x['name'])
except (ValueError, KeyError, TypeError):
print "JSON format error"
for site in profile_list:
xms_status_url = "ht tps://api.cloud.xirrus.com/v1/rest/api/profiles.json/"+site+"/accesspoints/statuses"
header ={
"Content-Type": "application/json",
ap_count = requests.get(xms_status_url, headers = header)
ap_status = json.dumps(ap_count.json())
ap_array = json.loads(ap_status)
#print site, ":", ap_array["upCount"], "/", ap_array["totalCount"], "Online"
print site, ":", ap_array["downCount"], "down." , ap_array["upCount"], "/" , ap_array["totalCount"], "Online" , ap_array["adminOfflineCount"], " Under maintenance."
