Http in without authorization
I'd like to try to connect web-hooks to node-red (for instance when a new google form is submitted). For this, I tried to use the http in node. I configured an URL /foo (if it matters, I run node-red behind a nginx proxy with basic , but when I run curl -X POST "https://my-server/foo" -H 'Content-Type: application/json' -d '{"mymessage": "data"}', I get an error (in curl's terminal) Unauthorized.
Am I doing anything wrong? Any idea how I could authorize any client to connect without password?
EDIT: oh wait, stupid me, I just enabled by mistake httpNodeAuth. That being said, when I do a curl request, node-red receives the message, but curl stays open until it times out. Any idea why no answer is sent?
EDIT2: problem solved, just needed to connect a http out node right after the http in with a 202 status code. Problem solved!
Problem solved, see edits above!
You solved you own issue - you will fit in well to the community -Welcome to it!
