HTTP request not working
Example flow:
        "id": "7f3738a666b6d04a",
        "type": "inject",
        "z": "dd671a1cf3809c0b",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 500,
        "y": 1360,
                "5c2cf5690476f240"
        "id": "b02330188bc77446",
        "type": "http request",
        "method": "POST",
        "ret": "obj",
        "paytoqs": "ignore",
        "url": "https://www.pling.as/psk/push.php",
        "tls": "",
        "persist": false,
        "proxy": "",
        "insecureHTTPParser": false,
        "authType": "",
        "senderr": false,
        "headers": [
                "keyType": "Content-Type",
                "keyValue": "",
                "valueType": "application/json",
                "valueValue": ""
        "credentials": {},
        "x": 790,
        "y": 1360,
                "a3b0130494d0225c"
        "id": "5c2cf5690476f240",
        "type": "function",
        "func": "msg.payload = \n\n{\n    \"serviceid\": \"<removed>\",\n    \"password\": \"<removed>\",\n    \"fromid\": \"<removed>\",\n    \"phoneno\": \"<removed>\",\n    \"txt\": \"This is a test.\",\n    \"unicode\": false\n}",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 640,
        "y": 1360,
                "b02330188bc77446"
        "id": "a3b0130494d0225c",
        "type": "debug",
        "name": "debug 56",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 940,
        "y": 1360,
This HTTP request does not work (nothing happens). It is supposed to send me a text message via an SMS API.
However, if I try using reqbin.com, it works perfectly.
And I get the SMS.
Why will this not work via Node-RED?
Add return msg to the end of your function
LOL how did I not see that. Thank you :joy:
