Http request payload
Hello
Somehow I can't get to the solution.
Is intended for an IO-Link Device with two analog out.
I have two sliders for entering the target output value, adding folders to 16bit Value Topic, merging them into one number, and now I want to transfer this to the master with an http request, but how do I pass the new value to the sliders?
I'm grateful for any help.
Philipp
        "id": "b7bcc2fa2dfe4f77",
        "type": "tab",
        "label": "Flow 3",
        "disabled": false,
        "info": "",
        "env": []
        "id": "e859f84d5936504a",
        "type": "ui_slider",
        "z": "b7bcc2fa2dfe4f77",
        "label": "slider-1",
        "tooltip": "",
        "group": "14b5f743f8a10343",
        "order": 0,
        "width": 0,
        "height": 0,
        "passthru": true,
        "outs": "end",
        "topic": "dpOut1",
        "topicType": "msg",
        "min": 0,
        "max": "650",
        "step": "5",
        "className": "",
        "x": 80,
        "y": 120,
                "0f693393d958ab90"
        "id": "f120df8155d96e93",
        "label": "slider-2",
        "tooltip": "",
        "order": 1,
        "width": 0,
        "height": 0,
        "passthru": true,
        "outs": "end",
        "topic": "dpOut2",
        "topicType": "msg",
        "min": 0,
        "max": "650",
        "step": "5",
        "className": "",
        "x": 80,
        "y": 320,
                "d06e3ed5730e0b2d"
        "id": "0f693393d958ab90",
        "type": "range",
        "minin": "0",
        "maxin": "650",
        "minout": "0",
        "maxout": "1000",
        "action": "scale",
        "round": true,
        "property": "payload",
        "x": 240,
        "y": 120,
                "c178d3a7ab805aab"
        "id": "d06e3ed5730e0b2d",
        "type": "range",
        "minin": "0",
        "maxin": "650",
        "minout": "0",
        "maxout": "1000",
        "action": "scale",
        "round": true,
        "x": 240,
        "y": 320,
                "460fabb846b4f234"
        "id": "c178d3a7ab805aab",
        "type": "function",
        "name": "topic pdOut1",
        "func": "msg.topic=\"pdOut1\";\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 410,
        "y": 120,
                "77837895ff6fd0eb"
        "id": "460fabb846b4f234",
        "type": "function",
        "name": "topic pdOut2",
        "func": "msg.topic=\"pdOut2\";\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 410,
        "y": 320,
                "77837895ff6fd0eb"
        "id": "77837895ff6fd0eb",
        "type": "join",
        "mode": "custom",
        "build": "object",
        "propertyType": "msg",
        "key": "topic",
        "joiner": "\\n",
        "joinerType": "str",
        "useparts": false,
        "accumulate": true,
        "timeout": "5",
        "count": "2",
        "reduceRight": false,
        "reduceExp": "",
        "reduceInit": "",
        "reduceInitType": "",
        "reduceFixup": "",
        "x": 630,
        "y": 220,
                "40844efd97a74e3d",
                "e9b1509ea10b06e8"
        "id": "40844efd97a74e3d",
        "type": "debug",
        "name": "join",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 810,
        "y": 160,
        "id": "e9b1509ea10b06e8",
        "type": "function",
        "name": "pdOut",
        "func": "var pdOut1= msg.payload.pdOut1;\nvar pdOut2= msg.payload.pdOut2;\nvar pdOut = (pdOut1 <<16) +pdOut2;\nmsg.payload.pdOut = pdOut;\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 810,
        "y": 240,
                "8dcc58553722529f",
                "28a33b22eed6dd38"
        "id": "8dcc58553722529f",
        "type": "debug",
        "name": "pdOut",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1010,
        "y": 160,
        "id": "28a33b22eed6dd38",
        "type": "function",
        "name": "function 7",
        "func": "var value = msg.payload.pdOut\nmsg.payload = { \n    code: \"request\", \n    cid: \"4\", \n    adr: \"/iolinkmaster/port[1]/iolinkdevice/pdout/setdata\",\n    data: \"value\"\n};\n\nreturn msg;\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1000,
        "y": 260,
                "0536f0a37e7a55b5",
                "3f89874dadd793c3"
        "id": "0536f0a37e7a55b5",
        "type": "http request",
        "method": "POST",
        "ret": "obj",
        "paytoqs": "ignore",
        "url": "http://169.254.12.28/",
        "tls": "",
        "persist": false,
        "proxy": "",
        "insecureHTTPParser": false,
        "authType": "",
        "senderr": false,
        "headers": [],
        "x": 1010,
        "y": 340,
                "d502c1a4387fc232"
        "id": "d502c1a4387fc232",
        "type": "debug",
        "name": "debug 28",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "x": 1180,
        "y": 340,
        "id": "3f89874dadd793c3",
        "type": "debug",
        "name": "debug 29",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1200,
        "y": 260,
        "id": "14b5f743f8a10343",
        "type": "ui_group",
        "name": "Test",
        "tab": "260eb08ed6b9a3a0",
        "order": 1,
        "disp": true,
        "width": 6,
        "collapse": false,
        "className": ""
        "id": "260eb08ed6b9a3a0",
        "type": "ui_tab",
        "name": "Test",
        "icon": "dashboard",
        "disabled": false,
        "hidden": false
        "id": "2ffba28f5d9dbbb5",
        "type": "global-config",
        "env": [],
        "modules": {
            "node-red-dashboard": "3.6.6"
You should have value not "value" in function node 7.
msg.payload = {
    code: "request",
    cid: "4",
    adr: "/iolinkmaster/port[1]/iolinkdevice/pdout/setdata",
    data: value   // <<<<<<<<<<< here
Thanks Dave,
it was my fault, but the return value have to be inside some quotation marks like this "value".
Do you mean that msg.payload.data has to be a string not a number, for example "42" ?
If so try const value = msg.payload.pdOut.toString()
Hi and welcome to the forum.
I hope @dynamicdave reply helped you.
I just want to add you are using far to many function nodes, which have overheads. here is an example of your flow minimised.
[{"id":"e859f84d5936504a","type":"ui_slider","z":"b7bcc2fa2dfe4f77","name":"","label":"slider-1","tooltip":"","group":"14b5f743f8a10343","order":0,"width":0,"height":0,"passthru":true,"outs":"end","topic":"pdOut1","topicType":"str","min":0,"max":"650","step":"5","className":"","x":75,"y":150,"wires":[["d06e3ed5730e0b2d"]]},{"id":"d06e3ed5730e0b2d","type":"range","z":"b7bcc2fa2dfe4f77","minin":"0","maxin":"650","minout":"0","maxout":"1000","action":"scale","round":true,"property":"payload","name":"","x":240,"y":210,"wires":[["77837895ff6fd0eb"]]},{"id":"f120df8155d96e93","type":"ui_slider","z":"b7bcc2fa2dfe4f77","name":"","label":"slider-2","tooltip":"","group":"14b5f743f8a10343","order":1,"width":0,"height":0,"passthru":true,"outs":"end","topic":"pdOut2","topicType":"str","min":0,"max":"650","step":"5","className":"","x":75,"y":270,"wires":[["d06e3ed5730e0b2d"]]},{"id":"77837895ff6fd0eb","type":"join","z":"b7bcc2fa2dfe4f77","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","useparts":false,"accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":370,"y":210,"wires":[["40844efd97a74e3d","e9b1509ea10b06e8"]]},{"id":"40844efd97a74e3d","type":"debug","z":"b7bcc2fa2dfe4f77","name":"join","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":440,"y":165,"wires":[]},{"id":"e9b1509ea10b06e8","type":"function","z":"b7bcc2fa2dfe4f77","name":"pdOut","func":"const pdOut1= msg.payload.pdOut1;\nconst pdOut2= msg.payload.pdOut2;\nconst pdOut = (pdOut1 <<16) +pdOut2;\nmsg.payload = { \n    code: \"request\", \n    cid: \"4\", \n    adr: \"/iolinkmaster/port[1]/iolinkdevice/pdout/setdata\",\n    data: pdOut\n};\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":515,"y":210,"wires":[["3f89874dadd793c3","0536f0a37e7a55b5"]]},{"id":"3f89874dadd793c3","type":"debug","z":"b7bcc2fa2dfe4f77","name":"debug 29","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":615,"y":165,"wires":[]},{"id":"0536f0a37e7a55b5","type":"http request","z":"b7bcc2fa2dfe4f77","name":"","method":"POST","ret":"obj","paytoqs":"ignore","url":"http://169.254.12.28/","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"x":680,"y":210,"wires":[["d502c1a4387fc232"]]},{"id":"d502c1a4387fc232","type":"debug","z":"b7bcc2fa2dfe4f77","name":"debug 28","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":795,"y":165,"wires":[]},{"id":"14b5f743f8a10343","type":"ui_group","name":"Test","tab":"260eb08ed6b9a3a0","order":1,"disp":true,"width":6,"collapse":false,"className":""},{"id":"260eb08ed6b9a3a0","type":"ui_tab","name":"Test","icon":"dashboard","disabled":false,"hidden":false},{"id":"84c13cd901f4fb6a","type":"global-config","env":[],"modules":{"node-red-dashboard":"3.6.6"}}]
Thanks to all special to E1cid with this clean flow. Great it works and I learned how to take it.
