Hue magic startup problems
Hi
I have start up issues with using hue magic 2.0.5.
Node-red v.5.0.7
I have connected my hue bridge successfully.
I can turn on my light with using an inject node so i know the light is working.
Question 1:
How can i toggle my light with a single button? is this only possible with using a function?
Question 2: How do i use the node Hue Scene?
thanks for support.
Did you look at the documentation ?
What kind of button ? Physical ? Web ?
Hi
I got it working with using the HA call service instead.
it is a physical button. Could not get the hue magic to work or hue scenes.
I got it working with the hue magic node, better yet my house is lit up by this node, physically, virtually and flowmatically. So why does it not work for you ?
note: node-red 5.0.7 does not exist.
Hi
i am using Node red in Home Assistant. here it is at version 5.0.7
could you share a string so i can see what i am doing different?
Node-red is at version 1.0.3
On the right top, hamburger menu, at the bottom.
