HUE on with transitionTime
i start my outdoor lights with a transitionTime when it goes dark.
but every the group start's with a brightness level of 100% and then start with dimming up from 0%-100%
why ?
How can i disable this?
my Script looks like:
let newPayload = {}
newPayload.brightness = 100;
newPayload.on = true;
newPayload.transitionTime = 900;
msg.payload = newPayload
thanks for help
pat
Did you find a solution?
Not yet..
It's seem to be an "error" with Hue lamp. You have to first define the first step (brightness 1%) and then start the transition.
I just create a flow that works, just edit the function and change the duration "1", and state "on off" in my example
var duration = 1 * 60;
    var msg1 = { payload: {
        "on": true,
        "brightness": 1 }}; // lowest brightness
    var msg2 = { payload: {
        "brightness": 100,
        "transitionTime": duration }};
    return [msg1, msg2];
Here the full flow:
[{"id":"5e24bede.c7586","type":"tab","label":"Flow 2","disabled":false,"info":""},{"id":"fd1a1a35.db6348","type":"function","z":"5e24bede.c7586","name":"Allume","func":"var duration = 1 * 60;\n    var msg1 = { payload: {\n        \"on\": true,\n        \"brightness\": 1 }}; // lowest brightness\n    var msg2 = { payload: {\n        \"brightness\": 100,\n        \"transitionTime\": duration }};\n    return [msg1, msg2];","outputs":2,"noerr":0,"initialize":"","finalize":"","x":230,"y":40,"wires":[["e6c88e0b.0ff4"],["e6c88e0b.0ff4"]]},{"id":"ce9d64db.7885b8","type":"inject","z":"5e24bede.c7586","name":"inject","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"0.1","topic":"","payload":"","payloadType":"date","x":110,"y":40,"wires":[["fd1a1a35.db6348"]]},{"id":"e6c88e0b.0ff4","type":"delay","z":"5e24bede.c7586","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":380,"y":40,"wires":[["f332ccc0.03dc8"]]},{"id":"f332ccc0.03dc8","type":"hue-light","z":"5e24bede.c7586","name":"Bureau ","bridge":"ed539dda.0eeb9","lightid":"13","colornamer":false,"skipevents":false,"universalevents":false,"x":560,"y":40,"wires":[[]]},{"id":"ed539dda.0eeb9","type":"hue-bridge","z":"","name":"LumiereRomelie","bridge":"192.168.1.6","key":"NL3-0NnY0S6GZ227stSfBD3u41fDMjFzXVxDfgUe","interval":"3000","disableupdates":false}]
Hey. Thanks i wil try it :slight_smile:
But you can set the brightness onyl when the bulb is on.
So at first on=true and then brightness=1, but when you set the bulb on, it switchs of the last state (eq. 100%) and second to the brightness of 1%
Hope you understand my post :slight_smile:
Your speak french no? Maybe we can switch in french as we are only you and me speaking in this post.
Anyway, I think you're right. This morning i used this function on 2 room. And in one of them the ligth turn 100% with no transition. In the other room, it was working well.
I will check history of each light
German :upside_down_face:
i think english will be ok...
thanks for checking
do you found a solution?
I increase the delay to 10s before start increasing the light.
which delay?
between on/brightness=1 and increasing ?
Exactly. I increased the delay to 10 secondes
i will try...
but i don't understand why only 1 bulb (of 3 in the group) won't dimm up?!
the command for on and dimm, i send to the group not to all the bulb's.
so i think the hue bridge send's out 3 times the same command, not one command for the group.
i think it's working!
thanks a lot!
pat
