I have this node installed:
node-red-contrib-queue-gate
I am seeing errors in my flows - I think at boot - and when raised with the writer they say it is a problem outside the node's scope.
The error message you've been getting is produced by the JavaScript interpreter when it doesn't know what to do. The older versions of
q-gatewould throw an error for certain inputs that are now ignored. You probably should check to see that your flow behaves properly, since the node may be ignoring instead of acting on those inputs.
This is the error I am seeing:
{"message":"TypeError: msg.payload.toLowerCase is not a function","source":{"id":"7bc998b7.b8c538","type":"q-gate","name":"qgate","count":1},"stack":"TypeError: msg.payload.toLowerCase is not a function\n at QueueGateNode._inputCallback (/home/pi/.node-red/node_modules/node-red-contrib-queue-gate/q-gate.js:79:37)\n at hooks.trigger (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/Node.js:203:26)\n at Object.trigger (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/hooks.js:113:9)\n at QueueGateNode.Node._emitInput (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/Node.js:195:11)\n at QueueGateNode.Node.emit (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/Node.js:179:25)\n at QueueGateNode.Node.receive (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/Node.js:476:10)\n at Immediate._onImmediate (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/flows/Flow.js:657:52)\n at runCallback (timers.js:705:18)\n at tryOnImmediate (timers.js:676:5)\n at processImmediate (timers.js:658:5)"}
{"message":"TypeError: msg.payload.toLowerCase is not a function","source":{"id":"93d25089.579ef8","type":"q-gate","name":"qgate","count":1},"stack":"TypeError: msg.payload.toLowerCase is not a function\n at QueueGateNode._inputCallback (/home/pi/.node-red/node_modules/node-red-contrib-queue-gate/q-gate.js:79:37)\n at hooks.trigger (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/Node.js:203:26)\n at Object.trigger (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/hooks.js:113:9)\n at QueueGateNode.Node._emitInput (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/Node.js:195:11)\n at QueueGateNode.Node.emit (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/Node.js:179:25)\n at QueueGateNode.Node.receive (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/Node.js:476:10)\n at Immediate._onImmediate (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/flows/Flow.js:657:52)\n at runCallback (timers.js:705:18)\n at tryOnImmediate (timers.js:676:5)\n at processImmediate (timers.js:658:5)"}
All Greek to me.
But I am asking if someone can help me understand what is going on and why.
