I can change a button label but not the color
Hello to everyone, I'm having some problem in NodeRed dashboard 2:
I can change the label of a button sending the new label in msg.ui_update.label but not the color via msg.ui_update.buttonColor.
Any ideas on how I should proceeed?
Thanks to anyone that will help!
Below some scrrenshot and the code.
        "id": "fa1b121844b992ba",
        "type": "function",
        "z": "d04688f59dc87486",
        "name": "Generate Random Color",
        "func": "function getRandomColor() {\n    var letters = '0123456789ABCDEF';\n    var color = '#';\n    for (var i = 0; i < 6; i++) {\n        color += letters[Math.floor(Math.random() * 16)];\n    }\n    return color;\n}\nmsg.payload = getRandomColor();\nreturn msg;",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1020,
        "y": 5560,
                "f992d7d840bfe3d1",
                "e146243fb7af13d8"
        "id": "672f1731ace42520",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 790,
        "y": 5560,
                "fa1b121844b992ba"
        "id": "f992d7d840bfe3d1",
        "type": "debug",
        "name": "debug 261",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 1270,
        "y": 5600,
        "id": "7c89d852d57b2949",
        "type": "ui-button",
        "group": "ddc37e300a3739fd",
        "label": "test button",
        "order": 4,
        "width": 0,
        "height": 0,
        "emulateClick": false,
        "tooltip": "",
        "color": "{{msg.ui_update.color}}",
        "className": "",
        "icon": "lamp",
        "iconPosition": "right",
        "payload": "Button clicked",
        "payloadType": "str",
        "topic": "topic",
        "topicType": "str",
        "x": 1490,
        "y": 5560,
        "id": "e146243fb7af13d8",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "ui_update.buttonColor",
                "pt": "msg",
                "to": "payload",
                "tot": "msg"
                "t": "set",
                "p": "ui_update.label",
                "pt": "msg",
                "to": "payload",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1280,
        "y": 5560,
                "7c89d852d57b2949"
        "id": "ddc37e300a3739fd",
        "type": "ui-group",
        "name": "My Group",
        "page": "44d3feb2a1143d7b",
        "width": "1",
        "height": "1",
        "order": 1,
        "showTitle": true,
        "className": "G1",
        "visible": "true",
        "disabled": "false"
        "id": "44d3feb2a1143d7b",
        "type": "ui-page",
        "name": "OPC UA",
        "ui": "e0f25e8fb66a7667",
        "path": "/opcua",
        "icon": "home",
        "layout": "grid",
        "theme": "61eee6fc60281b9b",
        "order": 1,
        "className": "",
        "visible": true,
        "disabled": false
        "id": "e0f25e8fb66a7667",
        "type": "ui-base",
        "name": "My Dashboard",
        "path": "/dashboard",
        "includeClientData": true,
        "acceptsClientConfig": [
            "ui-notification",
            "ui-control"
        "showPathInSidebar": false,
        "showPageTitle": true,
        "navigationStyle": "default",
        "titleBarStyle": "default"
        "id": "61eee6fc60281b9b",
        "type": "ui-theme",
        "name": "Default Theme",
        "colors": {
            "surface": "#0094ce",
            "primary": "#0094ce",
            "bgPage": "#aea3a3",
            "groupBg": "#2bb828",
            "groupOutline": "#cccccc"
        "sizes": {
            "pagePadding": "12px",
            "groupGap": "12px",
            "groupBorderRadius": "4px",
            "widgetGap": "12px"
Welcome to the forum @lucamrc
You need an extra line at the start of your change node to initialise msg.ui_update as an object.
Alternatively this seems to work in your function, without a change node:
const newcolor = getRandomColor()
msg.ui_update = {
    "buttonColor": newcolor,
    "label": newcolor
@lucamrc
I’ve tried the same flow you provided, and everything seems to be working fine on my end. I'm currently using Node-RED Dashboard 1.18.1. Could you let me know which version of the dashboard you're using?
Also, it looks like you've already found an approach, as @jbudd mentioned initializing msg.ui_update in the change node or directly in your function. If you're still facing issues, sharing your dashboard version might help us debug it further!
Looking forward to your response.
It seems like the problem was the version, i was running an old version of NodeRed dashboard 2 (1.12. something). I updated and now everything seems to work well. Thanks for pointing out!
