hello everyone, i have been working in a project with node red v3.1.0
in my project i use the same gpio input en two flows and works fine but in node red v4.0.2 does´t works anyone have an idea about that?
What exactly does not work? I have not got a 4.0.2 system with the gpio nodes installed so I cannot test it.
Are these on the same computer and with the same operating system release?
I have installed the gpio node on a pi with NR 4.02 and it works ok. Can you show us how you have configured the node and also the startup log when you run, on the failing system
node-red-stop
node-red-start
no there are in two different raspberry with different operating system
raspbian GNU/linux 11(bullseye) works fine in raspberry pi 3
raspbian GNU/linux 12(bookworm) not works in raspberry pi 4
thanks
I suspect it may be Bookworm issue. I don't have a Bookworm system.
@dceejay are you able to comment on this?
hello everyone, i have a good news, today install Debian bullseye in my pi 4 with node red 4.0.2 and .......
and I tried cloning gpio4 and it worked very well
Thank you very much to each of you for the interest shown to solve this problem, which in conclusion, as @Colin said, was about the OS Bookworm.
The alternative solution, of course, is to just use one input node and distribute it to other tabs using link nodes or mqtt.
i decide to use mqtt and works fine thanks
