Not Appear in Nodes Panel
Hi @ztmaung, welcome to the forum.
What module are you trying to install?
Thank you , for your reply.
i want to use alibabacloud on my docker.
Please reupload the image.
Like it.
Are you saying node-red-contrib-alibabacloud doesn't appear in the "install" tab? Or that you have installed it but does not appear in the pallette (on the left hand side of node-red editor)
yes bro. i installed. but does not appear in the pallette.
Could you try this & see if it is available...
First hard refresh your browser CTRL+F5
Hold CTRL and click in the editor whitespace (to show the add node popup) then type ali or cloud to filter the node list - do you see it in there?
Also, could you check Devtools (F12) console - are there any errors?
There seems to be an issue with the node, i just installed the node, and sure enough the nodes aren't appearing.
Please create an ISSUE on their GitHub repository.
Yayyyyyy. Got It.
Thank you So much , my bros.
Created an issue on the repo.
https://github.com/chengyuhui/node-red-contrib-alibabacloud/issues/3
