Could someone please help me, is something missing in my code?
My Node:
https://www.npmjs.com/package/node-red-contrib-readdir
My Node:
It generally takes an hour or so for the flows site to catch up. If you read the docs, you’ll see that you can ping Nick, normally on Slack, after a set period. He can then give things a kick if needed.
See Cannot register Node-RED Library
Theres a problem with the npm search results that node-red uses.
If you go to npmjs.com and type your nodes name in in the popup you will see it has version 0.0.0
