Not finding a solution previously raised in the forum: Http request options, I had to downgrade and install version 1.3, that way the http works correctly for me request with the keep alive option selected, with version 2.2 it has not worked for me after three days of trying different things, I use the http request to send data through POS to the traccar server locally and this needs the connection type to be keep alive . At the moment I have solved the problem but it is not the idea to work with an old version of nodered. Some ideas, what could be the problem? Thank you!
