Hello, I'm French and I don't speak good English,so I have a problem and when I look the log of nod red I see : Welcome to Node-RED
26 Apr 22:57:21 - [info] Node-RED version: v0.20.5
26 Apr 22:57:21 - [info] Node.js version: v10.15.3
26 Apr 22:57:21 - [info] Linux 4.14.98-v7+ arm LE
26 Apr 22:57:24 - [info] Loading palette nodes
26 Apr 22:57:40 - [info] Dashboard version 2.14.0 started at /ui
26 Apr 22:57:41 - [warn] ------------------------------------------------------
26 Apr 22:57:41 - [warn] [node-red-contrib-google-home-notify-volume-adjustable/google-notify] Type already registered
26 Apr 22:57:41 - [warn] [node-red-contrib-mi-devices/xiaomi-yeelight] Error: /home/pi/.node-red/node_modules/node-red-contrib-mi-devices/dist/nodes/yeelight/index.html does not exist
26 Apr 22:57:41 - [warn] [yeelight/noble] Type already registered
26 Apr 22:57:41 - [info] Settings file : /home/pi/.node-red/settings.js
26 Apr 22:57:41 - [info] Context store : 'default' [module=memory]
26 Apr 22:57:41 - [info] User directory : /home/pi/.node-red
26 Apr 22:57:41 - [warn] Projects disabled : editorTheme.projects.enabled=false
26 Apr 22:57:41 - [info] Flows file : /home/pi/.node-red/flows_raspberrypi.json
your credentials.
26 Apr 22:57:41 - [info] Starting flows
26 Apr 22:57:42 - [info] [yeelight-compat-hue-config:ab891a76.9433b8] Connecting to Yeelight 192.168.1.16:55443
26 Apr 22:57:42 - [info] [yeelight-compat-hue-config:b4be7f8b.c53b2] Connecting to Yeelight 61.1.861.291:55443
26 Apr 22:57:44 - [info] nora (KWEm0): connecting
26 Apr 22:57:45 - [info] Started flows
26 Apr 22:57:45 - [info] Server now running at http://127.0.0.1:1880/
fileServer listening on port 8098
Error at 61.1.861.291:55443 { Error: getaddrinfo ENOTFOUND 61.1.861.291 61.1.861.291:55443
at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:56:26)
errno: 'ENOTFOUND',
code: 'ENOTFOUND',
syscall: 'getaddrinfo',
hostname: '61.1.861.291',
host: '61.1.861.291',
port: '55443' }
26 Apr 22:57:46 - [info] [yeelight-compat-hue-config:b4be7f8b.c53b2] Disconnected from 61.1.861.291:55443
Error at 192.168.1.16:55443 { Error: connect ECONNREFUSED 192.168.1.16:55443
at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1097:14)
errno: 'ECONNREFUSED',
code: 'ECONNREFUSED',
syscall: 'connect',
address: '192.168.1.16',
port: 55443 }
26 Apr 22:57:46 - [info] [yeelight-compat-hue-config:ab891a76.9433b8] Disconnected from 192.168.1.16:55443
26 Apr 22:57:46 - [info] [mqtt-broker:Raspberry] Connected to broker: mqtt://192.168.1.36:1883
26 Apr 22:57:47 - [red] Uncaught Exception:
26 Apr 22:57:47 - Error: ENOENT: no such file or directory, open 'D:\tmp\GHCache/WESH_ALORS.mp3'
nodered.service: Main process exited, code=exited, status=1/FAILURE
nodered.service: Unit entered failed state.
nodered.service: Failed with result 'exit-code'.
nodered.service: Service hold-off time over, scheduling restart.
Stopped Node-RED graphical event wiring tool.
26 Apr 22:57:53 - [info]
i have a lot of eror but i don't knox how to resolve it
if you can help me Thank You
