I have to start somewhere. Home automation control
I am thinking of getting a bit of work done and getting 240v (AC/Main) stuff down/controlled.
I live in "Oz" and there aren't too many options for a central system.
There is a system from Clipsal called C-Bus. But that is its own standalone system.
Can Node-Red talk to this system? Does anyone know?
Thanks in advance.
The best place to start would probably be flows.nodered.org
Then a search using your internet search engine of choice, you should quickly find some avenues worth more investigation...
Well, while looking I see z-wave is supported.
I may have to go down that path as c-bus didn't quite show anything other than mpr121. What ever that is.
Really? With one "google" for "C-bus node-red" I found pages where people are integrating the two via MQTT.
But this is a search that you can easily do...
I can't argue with what you said.
I tried and didn't really get much. So I looked in the library and entered C-Bus and got a node that mentioned.... mpr121.
So while looking at other "home automation" stuff I saw z-wave and looked in the library.
Found the node right away.
So I guess that's that.
You must have a better google than me.
But I live in Oz. The back water of the internet.
Google don't like me much these days - dunno why.
I really get weird results for searches.
You should clear out your browser history/cookies/etc and clear out your search history in Google as well.
Then switch to an alternate such as startpage.com.
